problem wtih reading and wirting cs5460 with at89c52
selvam.e
Newbie level 1
hello experts,
i here with atached part of code which is used for getting register values , but the problem is i'm not getting any values . im looking a guidance for read/write cs5460 with at89c52, software which im using is keil version.
warm regards,
selvam, bangalore.
cmd_5460(0xff); //nop
delay(1000);
delay(1000);
delay(1000);
cmd_5460(0xfe); //nop
write_5460(0x4a000012); //writing cycle count reg; with value of 18d
delay(1000);
write_5460(0x5e000001); //writing status register; with value of 1;
delay(1000);
write_5460(0x40000004);//writing config reg wih value of 4 for clock divider;
delay(1000);
write_5460(0x78000008); //writing control register for synchronize with adc clock;
delay(1000);
write_5460(0x74800000); //writing mask registr o mask all bits except drdy bit;
cmd_5460(0xe8);// start conersiion for continuous computation cycle
delay(1000);
cmd_5460(0x16);// read irms register
read_5460();
void cmd_5460(unsigned char cmd)
unsigned char i=8;
while(i>0)
if(cmd & 0x80)
sdi_5460=1;
sclk_5460=0; //clk applying
delay(1000);
sclk_5460=1;
delay(1000);
else
sdi_5460=0;
delay(1000);
sclk_5460=1;
delay(1000);
i--;
cmd=cmd << 1;
unsigned long read_5460(void)
unsigned char i,j=0;
unsigned long temp;// temp is used to store read value
temp=0;
while(j<3)
i=7;
sdi_5460=1;
while(i>0)
temp=temp<<1;
delay(1000);
sclk_5460=1;
delay(1000);
if(sdo_5460==1)
temp=temp|0x00000001;
i=i-1;
sdi_5460=0; /writing zero at eighth bit to be read.
temp = temp << 1;
delay(1000);
sclk_5460=1;
delay(1000);
if(sdo_5460==1)
temp = temp|0x00000001;
j=j+1;
if(temp==0)
P2=disp1;
P0=1;
else
P2=disp2;
P0=1;
return(temp);
void delay(unsigned int q)
while(q>=1)
q=q-1;
void write_5460(unsigned long reg_value)
unsigned char k=32;
while(k>=1)
if (reg_value & 0x80000000)
sdi_5460=1;
delay(1000);
sclk_5460=1;
delay(1000);
else
sdi_5460=0;
delay(1000);
sclk_5460=1;
delay(1000);
reg_value = reg_value << 1;
k=k-1;
