permute
Advanced Member level 3
I am having issues trying to put code on a microblaze and have it run.
My goal is to get uboot to run. linux can already run if I load it from jtag. uboot can also run from jtag. Now I want to get uboot to run from flash.
Thus far I've not been able to figure this out. The appnotes aren't very helpful on this topic. I've seen the following:
1.) write a bootloader that jumps to the location of uboot in flash.
2.) use xilinx's srec bootloader.
and "uboot" has three files, an elf, a bin, and a srec. I'm not sure which one to put in flash.
Thus far, my biggest challenge is that I also can't get the bootloader to work correctly. the srec bootloader from xilinx doesn't work from BRAM or JTAG. my bootloader doesn't run from a BRAM, but will run from jtag. unfortunantly uboot doesn't load. it jumps to 0x86E00000, which is where u-boot is in flash and after that, it fails to run u-boot (binary).
So in summary:
is there any way to get the microblaze to run an elf project at start? right now it just executes a few random instructions in a loop. Loading from JTAG gives different results (actually jumps to 0x86E00000).
What do I need to do? use u-boot SREC and the SREC bootloader? use a bootloader that jumps to flash and the u-boot.{src,bin,elf}?
---------- Post added at 23:26 ---------- Previous post was at 23:20 ----------
also, how do I put u-boot onto flash? I looked at the results from flash for where it thinks u-boot is, and compared it to the first lines of u-boot and they don't match any combination of bit-reversed, endian reversed, bit inverted, ect... the data on the flash just doesn't match the file I included with the mcs file. To make the mcs file, I used xilinx's wizard in impact, placing u-boot.bin at 0x00700000. When I build the file, it gives a warning saying that the location will be moved to 0x00E00000 because of the data bus width.
So in summary:
