Re: Problem with waveguide slot array antenna 23.6 GHz resonance vs 24.1 GHz simulati
What I want to see is very small losses at any resonance from 24 to 26GHz.
At first my idea was to build 3 prototypes with some frequency step, compare simulation to reality, and then do some tuning in model.
Problem is prototype resonances do not shift with slot length.
I can't understand differences between simulation and prototypes
Simulation:
L+DL [mm] - resonance around 23.2 GHz
L+0 [mm] - resonance around 24.100GHz
L-DL [mm] - resonance around 25 GHz
Prototypes:
L+DL [mm] - resonance around 23.6 GHz - strongest received doppler reflection from rotating fan. But i think that S11 is very poor, worse than -6dB.
L+0 [mm] - resonance around 23.6 GHz
L-DL [mm] - resonance around 23.6 GHz
Why resonant frequency almost the same? At first I suspected that slots does not radiate at all, and maybe 23.6 GHz is some connection leakage dip in S11 or waveguide resonance. But covering TX or RX antenna in radiation direction gives significant effect. Also I observe that beam is pretty narrow in horizontal direction (8x1 arrays are placed horizontally) and wide in vertical direction, just by pointing antennas toward rotating fan.
Maybe problem with guided wavelength, but from my (small) experience air filled guides match simulation very well in all aspects.
I am planning to make more prototypes and search for better resonances:
two-slot arrays, varying:
1. slot length
2. slot distance
3. slot inclination
3 values for each parameter, 3x3x3=27 prototypes.
or 3x3=9 prototypes, and tune slot length by drilling
also can tune waveguide short distance somehow.
Any ideas?
