problem with vhdl code
barathceg
Newbie level 1
Newbie level 1
sir i have vhdl code for 32 bit floating point adder , i checked code it seems correct but it gives wrong result , so any one kindly help me for verify the code and correct the code also give the inputs
  • New Text Document.txt
Wow, that is some of the worst code Ive ever seen in terms of formatting. No way am I going anywhere near any of the 500 lines of it.
Have you got a testbench? have you done any debugging yourself?
Why not use the floating point provided by your device manufacturer?
Provided you want (or have been advised) to write a floating point adder from the sratch, why did you choose this strange combination of behavioral code but structural code for almost trivial operations?
Why don't you post a readable *.vhd file with usual indention and a reasonable amount of comments?
