Ipanema
Member level 1
oscillation
My circuit consists of a long Limiting Amplifier stages and a closed cloop temperature and process compensation biasing circuit. For AC analysis, the phase margin is 100degree, after applying miller compensation.
My problem is the close loop compensation circuit shows a very small amplitude oscillation (I said oscillation and not coupling noise because it does not exhibit the same pattern as the input signal) when I applied ac signal to the input. When I removed the AC input signals and replaced with a dc signal, the oscillation is gone.
In this case, do you think that my circuit is stable? Why would it show oscillation only when there is an AC input signal? Pls Advise.
Thanks.
Thanks.
