kappa_am
Full Member level 6
- Joined
- Jul 16, 2012
- Messages
- 331
- Helped
- 19
- Reputation
- 38
- Reaction score
- 19
- Trophy points
- 1,298
- Location
- Vancouver
- Activity points
- 3,859
Hi all,
I use PSCAD/EMTDC software to simulate power electric system. this software if base on fortran, so I have to program my user defined component by using fortran. recently, I programed a component in which I need some 2 dimensional matrices. but I can define one matrix just in fist line. when I enter the other matrix in second line it gives this error: "Main.f(50) : Error: Syntax error, found END-OF-STATEMENT when expecting one of: , : )". while it work with matrix which is defined using same method. I checked however I write the line correctly but in overall program which is constructed by putting together all components subprogram it goes wrong.
I write:
#LOCAL INTEGER WS(10,4)
#LOCAL INTEGER WSQ(10,4)
#LOCAL INTEGER CAPV(3) ! Number of Capacitors
#LOCAL REAL CPS(2) ! Number of phases
#LOCAL INTEGER ZC(2)
But in overall program it is:
! Internal Variables
INTEGER WS(10, 4), WSQ(10, CAPV(3), ZC(2)
what should I do? I really confused!!
any comment is appreciated.
Thank you
I write:
Thank you
