Problem with using Frequency Domain Solver in CST
andrewmorcos
Newbie level 6
Hey there,
In CST i read that the frequency domain solver is better used with structure having dimensions less than the wavelength. So i had my sturcture and got good results using Frequency domain solver. I tried to simulate the same structure with Transient solver but results were so bad... Does anyone know why is that? and is there a solution to that?
I also want to have a parameter sweep for induced current in 1 receiving antenna while the transmitting antenna is moving on an axis. I want to plot a voltage-distance graph. is that possible???
Thank you in advance
