firesky1982
Newbie level 3
I need help with Trisb portb. Can any help me with problem in the code that i have?
; mclockT3.asm - modified for 180 degree brush motor
; OK to add 8th LED - blanked in table and 2 other places
; watchdog timer used to ensure startup under all powerups
; "The Propeller" mechanically scanned LED clock
; Bob Blick February 12, 1997
; Licensed under terms of the GNU General Public License, [url]www.gnu.org[/url]
; No warranties expressed or implied
; Bob Blick February 18, 2002
list p=16F84
radix hex
include "p16F84.inc"
; remember to set blast-time options: OSC=regular xtal, WDT=ON
; timings all based on 4 MHz crystal
; are these equates already in the include file? someday I'll look.
w equ 0
f equ 1
; Start of available RAM.
cblock 0x0C
safe_w ;not really temp, used by interrupt svc
safe_s ;not really temp, used by interrupt svc
period_count ;incremented each interrupt
period_dup ;copy of period_count safe from interrupt
period_calc ;stable period after hysteresis calc.
flags ;b2=int b1=minute b4=edge
dot_index ;which column is being displayed
digit_index ;which digit is being displayed
hours ;in display format, not hex(01-12)
minutes ;00 to 59
bigtick_dbl ;incremented each interrupt
bigtick_hi
bigtick_lo
keys ;key value
scratch ;scratch value
tick ;used by delay
endc
; Start of ROM
org 0x00 ;Start of code space
goto Start
; INTERRUPT SERVICE ROUTINE
org 0x04 ;interrupt vector
Intsvc movwf safe_w ;save w
swapf STATUS,w ;swap status, w
movwf safe_s ;save status(nibble swap, remember)
; done saving, now start working
; increment period count
incf period_count,f
btfsc STATUS,Z ;zero set means overflow
decf period_count,f
; clear watchdog timer to ensure startup
clrwdt
; 234375 interrupts every minute. Increment the bigtick each time.
incf bigtick_lo,f
btfsc STATUS,Z
incf bigtick_hi,f
btfsc STATUS,Z
incfsz bigtick_dbl,f
goto Bigtick_out
; here? bigtick has rolled over to zero and one minute has passed.
; reload bigtick and set a flag for the main counter
movlw 0xFC ;234375 = 0x039387
movwf bigtick_dbl ;0 - 0x039387 = 0xFC6C79
movlw 0x6C
movwf bigtick_hi
movlw 0x79
movwf bigtick_lo
bsf flags,1 ;notify Keep_time
Bigtick_out
; done working, start restoring
swapf safe_s,w ;fetch status, reswap nibbles
movwf STATUS ;restore status
swapf safe_w,f ;swap nibbles in preparation
swapf safe_w,w ;for the swap restoration of w
bcf INTCON,2 ;clear interrupt flag before return
retfie ;return from interrupt
; CHARACTER LOOKUP TABLE
; ignore high bit. set=LED off, clear=LED on, bit0=bottom LED, bit6=top LED
Char_tbl
addwf PCL,f
dt 0xC1,0xBE,0xBE,0xBE,0xC1 ;"O"
dt 0xFF,0xDE,0x80,0xFE,0xFF ;"1"
dt 0xDE,0xBC,0xBA,0xB6,0xCE ;"2"
dt 0xBD,0xBE,0xAE,0x96,0xB9 ;"3"
dt 0xF3,0xEB,0xDB,0x80,0xFB ;"4"
dt 0x8D,0xAE,0xAE,0xAE,0xB1 ;"5"
dt 0xE1,0xD6,0xB6,0xB6,0xF9 ;"6"
dt 0xBF,0xB8,0xB7,0xAF,0x9F ;"7"
dt 0xC9,0xB6,0xB6,0xB6,0xC9 ;"8"
dt 0xCF,0xB6,0xB6,0xB5,0xC3 ;"9"
dt 0xFF,0xC9,0xC9,0xFF,0xFF ;":"
Char_tbl_end
; SUBROUTINES STARTING HERE
; clear important bits of ram
Ram_init movlw 0x07
movwf keys
movlw 0x12 ;why do clocks always start
movwf hours ;at 12:00 ?
clrf minutes
clrf dot_index
clrf digit_index
movlw 0xFC
movwf bigtick_dbl
retlw 0
; unused pins I am setting to be outputs
Port_init movlw 0x00 ;all output, b7=unused
bsf STATUS,RP0 ;select memory bank1
movwf TRISB ;portB as output
bcf STATUS,RP0 ;return to bank0
movlw b'00010111' ;port a has 5 pins. I need 4 inputs
;b0=minutes, b1=10mins, b2=hours
;b3=unused, b4=rotation index
tris PORTA ;on port a
retlw 0
; get timer-based interrupts going
Timer_init bcf INTCON,2 ;clear TMR0 int flag
bsf INTCON,7 ;enable global interrupts
bsf INTCON,5 ;enable TMR0 int
clrf TMR0 ;clear timer
clrwdt ;why is this needed? just do it..
movlw b'11011000' ;set up timer. prescaler(bit3)bypassed
option ;send w to option. generate warning.
clrf TMR0 ;start timer
retlw 0
; test for index in rotation and store period in period_dup
Check_index movf PORTA,w ;get the state of port a
xorwf flags,w ;compare with saved state
andlw b'00010000' ;only interested in bit 4
btfsc STATUS,Z ;test for edge
retlw 0 ;not an edge, same as last
xorwf flags,f ;save for next time
btfsc flags,4 ;test for falling edge
retlw 0 ;must have been a rising edge
movf period_count,w ;make a working copy
movwf period_dup ;called period dup
clrf period_count ;a fresh start for next rotation
clrf digit_index ;set to first digit
clrf dot_index ;first column
; calculate a period that does not dither or jitter
; period will not be changed unless new period is really different
movf period_calc,w
subwf period_dup,w ;find difference
btfss STATUS,C ;carry flag set means no borrow
goto Calc_period_neg ;must be other way
sublw 2 ;allowable deviation = 3
btfss STATUS,C ;borrow won't skip
incf period_calc ;new value much larger than calc
retlw 0
Calc_period_neg addlw 2 ;allowable deviation = 3
btfss STATUS,C ;carry will skip
decf period_calc ;no carry means it must be changed
retlw 0
; change LED pattern based on state of digit_index and dot_index
Display_now movlw 0x05
xorwf dot_index,w ;test for end of digit
movlw 0xFF ;pattern for blank column
btfsc STATUS,Z
goto D_lookup_3 ;it needs a blank
bcf STATUS,C ;clear carry before a rotate
rlf digit_index,w ;double the index because each
addwf PCL,f ;takes two instructions
D_10hr swapf hours,w
goto D_lookup ;what a great rush of power
D_1hr movf hours,w ;I feel when modifying
goto D_lookup ;the program counter
D_colon movlw 0x0A
goto D_lookup
D_10min swapf minutes,w
goto D_lookup
D_1min movf minutes,w
goto D_lookup
D_nothing retlw 0
D_lookup andlw b'00001111' ;strip off hi bits
movwf scratch ;multiply this by 5 for lookup
addwf scratch,f ;table base position
addwf scratch,f ;is this cheating?
addwf scratch,f ;I think not.
addwf scratch,f ;I think it is conserving energy!
btfss STATUS,Z ;test for zero
goto D_lookup_2 ;not a zero
movf digit_index,f ;this is just to test/set flag
movlw 0xFF ;this makes a blank LED pattern
btfsc STATUS,Z ;test if it is 10 hrs digit
goto D_lookup_3 ;it's a leading zero
D_lookup_2 movf dot_index,w ;get column
addwf scratch,w ;add it to digit base
call Char_tbl ;get the dot pattern for this column
D_lookup_3 movwf PORTB ;send it to the LEDs
bcf STATUS,C ;clear carry flag before rotate
rrf period_calc,w ;period/2 used for dot clock
addlw 0xF4 ;subtract 12 to compensate for overhead
call Delay ;width of digits with this delay
incf dot_index,f ;increment to the next column
movlw 0x06 ;6 columns is a digit plus space
xorwf dot_index,w ;next digit test
btfss STATUS,Z
retlw 0 ;not a new digit
clrf dot_index ;new digit time
incf digit_index,f
retlw 0 ;Display_now done.
; a short delay routine
Delay movwf tick
Delay_loop decfsz tick,f
goto Delay_loop ;w is not damaged, so Delay can
return ;be recalled without reloading
; test for keypress and call time adjust if needed
Check_keys movf PORTA,w ;get port "a"
xorwf keys,w ;compare with previous
andlw b'00000111' ;only care about button pins
btfsc STATUS,Z ;zero set=no buttons
retlw 0 ;return
xorwf keys,f ;store key value
movlw 0x64 ;a fairly long delay will
movwf scratch ;prevent key bounces
Key_delay movlw 0xFF
call Delay
decfsz scratch
goto Key_delay
btfss keys,2 ;test "minutes" button
goto Inc_mins
btfss keys,1 ;test "tens" button
goto Inc_tens
btfss keys,0 ;test "hours" button
goto Inc_hours
retlw 0 ;must be a glitch. yeah, right!
; increment ten minutes
Inc_tens movlw 0x0A
movwf scratch ;scratch has ten
Inc_tens_loop call Inc_mins
decfsz scratch
goto Inc_tens_loop ;another minute added
retlw 0
; increment one hour
Inc_hours movlw 0x12
xorwf hours,w
btfsc STATUS,Z
goto Inc_hours_12
movlw 0x07 ;this part gets a little sloppy
addwf hours,w
movlw 0x07
btfss STATUS,DC
movlw 1
addwf hours,f
retlw 0
Inc_hours_12 movlw 0x01
movwf hours
retlw 0
; increment the time based on flags,1 as sent by interrupt routine
; Inc_mins loop also used by time-setting routine
Keep_time btfss flags,1 ;the minutes flag
retlw 0 ;not this time
bcf flags,1 ;clear the minutes flag
Inc_mins movlw 0x07 ;start incrementing time
addwf minutes,w ;add 7 minutes into w
btfsc STATUS,DC ;did adding 7 cause digit carry?
goto Sixty_mins ;then test for an hour change
incf minutes ;otherwise add 1 for real
retlw 0 ;and go back
Sixty_mins movwf minutes ;save the minutes
movlw 0x60 ;test for 60
xorwf minutes,w ;are minutes at 60?
btfss STATUS,Z
retlw 0 ;no? go back
clrf minutes ;otherwise zero minutes
goto Inc_hours ;and increment hours
; End of subroutines
; Program starts here
Start call Ram_init ;set variables to nice values
call Port_init ;set port directions
call Timer_init ;start timer based interrupt
; Done initializing, start the endless loop.
Circle ;begin the big loop
; detect falling edge on PORTA,4 to determine rotary index
; calculate rotation period and store in period_dup
; compare with working period(period_calc) and adjust if way different
call Check_index
; check display state and change if needed
call Display_now
; check keyboard and adjust time
call Check_keys
; check minute flag and increment time if a minute has passed
call Keep_time
; gentlemen, that's a clock, keep it rolling
goto Circle ;you heard the man, get going!
end
; end of file
firesky1982 said:Code:;-------- ; mclockT3.asm - modified for 180 degree brush motor ; OK to add 8th LED - blanked in table and 2 other places ; watchdog timer used to ensure startup under all powerups ; "The Propeller" mechanically scanned LED clock ; Bob Blick February 12, 1997 ; Licensed under terms of the GNU General Public License, [url]www.gnu.org[/url] ; No warranties expressed or implied ; Bob Blick February 18, 2002 ;-------- list p=16F84 radix hex include "p16F84.inc" ;-------- ; remember to set blast-time options: OSC=regular xtal, WDT=ON ; timings all based on 4 MHz crystal ;-------- ; are these equates already in the include file? someday I'll look. ;-------- w equ 0 f equ 1 ;-------- ; Start of available RAM. ;-------- cblock 0x0C safe_w ;not really temp, used by interrupt svc safe_s ;not really temp, used by interrupt svc period_count ;incremented each interrupt period_dup ;copy of period_count safe from interrupt period_calc ;stable period after hysteresis calc. flags ;b2=int b1=minute b4=edge dot_index ;which column is being displayed digit_index ;which digit is being displayed hours ;in display format, not hex(01-12) minutes ;00 to 59 bigtick_dbl ;incremented each interrupt bigtick_hi bigtick_lo keys ;key value scratch ;scratch value tick ;used by delay endc ;-------- ; Start of ROM ;-------- org 0x00 ;Start of code space goto Start ;-------- ; INTERRUPT SERVICE ROUTINE ;-------- org 0x04 ;interrupt vector Intsvc movwf safe_w ;save w swapf STATUS,w ;swap status, w movwf safe_s ;save status(nibble swap, remember) ;-------- ; done saving, now start working ; increment period count ;-------- incf period_count,f btfsc STATUS,Z ;zero set means overflow decf period_count,f ; clear watchdog timer to ensure startup clrwdt ; 234375 interrupts every minute. Increment the bigtick each time. incf bigtick_lo,f btfsc STATUS,Z incf bigtick_hi,f btfsc STATUS,Z incfsz bigtick_dbl,f goto Bigtick_out ;-------- ; here? bigtick has rolled over to zero and one minute has passed. ; reload bigtick and set a flag for the main counter ;-------- movlw 0xFC ;234375 = 0x039387 movwf bigtick_dbl ;0 - 0x039387 = 0xFC6C79 movlw 0x6C movwf bigtick_hi movlw 0x79 movwf bigtick_lo bsf flags,1 ;notify Keep_time Bigtick_out ;-------- ; done working, start restoring ;-------- swapf safe_s,w ;fetch status, reswap nibbles movwf STATUS ;restore status swapf safe_w,f ;swap nibbles in preparation swapf safe_w,w ;for the swap restoration of w bcf INTCON,2 ;clear interrupt flag before return retfie ;return from interrupt ;-------- ; CHARACTER LOOKUP TABLE ; ignore high bit. set=LED off, clear=LED on, bit0=bottom LED, bit6=top LED ;-------- Char_tbl addwf PCL,f dt 0xC1,0xBE,0xBE,0xBE,0xC1 ;"O" dt 0xFF,0xDE,0x80,0xFE,0xFF ;"1" dt 0xDE,0xBC,0xBA,0xB6,0xCE ;"2" dt 0xBD,0xBE,0xAE,0x96,0xB9 ;"3" dt 0xF3,0xEB,0xDB,0x80,0xFB ;"4" dt 0x8D,0xAE,0xAE,0xAE,0xB1 ;"5" dt 0xE1,0xD6,0xB6,0xB6,0xF9 ;"6" dt 0xBF,0xB8,0xB7,0xAF,0x9F ;"7" dt 0xC9,0xB6,0xB6,0xB6,0xC9 ;"8" dt 0xCF,0xB6,0xB6,0xB5,0xC3 ;"9" dt 0xFF,0xC9,0xC9,0xFF,0xFF ;":" Char_tbl_end ;-------- ; SUBROUTINES STARTING HERE ;-------- ; clear important bits of ram ;-------- Ram_init movlw 0x07 movwf keys movlw 0x12 ;why do clocks always start movwf hours ;at 12:00 ? clrf minutes clrf dot_index clrf digit_index movlw 0xFC movwf bigtick_dbl retlw 0 ;-------- ; unused pins I am setting to be outputs ;-------- Port_init movlw 0x00 ;all output, b7=unused bsf STATUS,RP0 ;select memory bank1 movwf TRISB ;portB as output bcf STATUS,RP0 ;return to bank0 movlw b'00010111' ;port a has 5 pins. I need 4 inputs ;b0=minutes, b1=10mins, b2=hours ;b3=unused, b4=rotation index tris PORTA ;on port a retlw 0 ;-------- ; get timer-based interrupts going ;-------- Timer_init bcf INTCON,2 ;clear TMR0 int flag bsf INTCON,7 ;enable global interrupts bsf INTCON,5 ;enable TMR0 int clrf TMR0 ;clear timer clrwdt ;why is this needed? just do it.. movlw b'11011000' ;set up timer. prescaler(bit3)bypassed option ;send w to option. generate warning. clrf TMR0 ;start timer retlw 0 ;-------- ; test for index in rotation and store period in period_dup ;-------- Check_index movf PORTA,w ;get the state of port a xorwf flags,w ;compare with saved state andlw b'00010000' ;only interested in bit 4 btfsc STATUS,Z ;test for edge retlw 0 ;not an edge, same as last xorwf flags,f ;save for next time btfsc flags,4 ;test for falling edge retlw 0 ;must have been a rising edge movf period_count,w ;make a working copy movwf period_dup ;called period dup clrf period_count ;a fresh start for next rotation clrf digit_index ;set to first digit clrf dot_index ;first column ; calculate a period that does not dither or jitter ; period will not be changed unless new period is really different movf period_calc,w subwf period_dup,w ;find difference btfss STATUS,C ;carry flag set means no borrow goto Calc_period_neg ;must be other way sublw 2 ;allowable deviation = 3 btfss STATUS,C ;borrow won't skip incf period_calc ;new value much larger than calc retlw 0 Calc_period_neg addlw 2 ;allowable deviation = 3 btfss STATUS,C ;carry will skip decf period_calc ;no carry means it must be changed retlw 0 ;-------- ; change LED pattern based on state of digit_index and dot_index ;-------- Display_now movlw 0x05 xorwf dot_index,w ;test for end of digit movlw 0xFF ;pattern for blank column btfsc STATUS,Z goto D_lookup_3 ;it needs a blank bcf STATUS,C ;clear carry before a rotate rlf digit_index,w ;double the index because each addwf PCL,f ;takes two instructions D_10hr swapf hours,w goto D_lookup ;what a great rush of power D_1hr movf hours,w ;I feel when modifying goto D_lookup ;the program counter D_colon movlw 0x0A goto D_lookup D_10min swapf minutes,w goto D_lookup D_1min movf minutes,w goto D_lookup D_nothing retlw 0 D_lookup andlw b'00001111' ;strip off hi bits movwf scratch ;multiply this by 5 for lookup addwf scratch,f ;table base position addwf scratch,f ;is this cheating? addwf scratch,f ;I think not. addwf scratch,f ;I think it is conserving energy! btfss STATUS,Z ;test for zero goto D_lookup_2 ;not a zero movf digit_index,f ;this is just to test/set flag movlw 0xFF ;this makes a blank LED pattern btfsc STATUS,Z ;test if it is 10 hrs digit goto D_lookup_3 ;it's a leading zero D_lookup_2 movf dot_index,w ;get column addwf scratch,w ;add it to digit base call Char_tbl ;get the dot pattern for this column D_lookup_3 movwf PORTB ;send it to the LEDs bcf STATUS,C ;clear carry flag before rotate rrf period_calc,w ;period/2 used for dot clock addlw 0xF4 ;subtract 12 to compensate for overhead call Delay ;width of digits with this delay incf dot_index,f ;increment to the next column movlw 0x06 ;6 columns is a digit plus space xorwf dot_index,w ;next digit test btfss STATUS,Z retlw 0 ;not a new digit clrf dot_index ;new digit time incf digit_index,f retlw 0 ;Display_now done. ;-------- ; a short delay routine ;-------- Delay movwf tick Delay_loop decfsz tick,f goto Delay_loop ;w is not damaged, so Delay can return ;be recalled without reloading ;-------- ; test for keypress and call time adjust if needed ;-------- Check_keys movf PORTA,w ;get port "a" xorwf keys,w ;compare with previous andlw b'00000111' ;only care about button pins btfsc STATUS,Z ;zero set=no buttons retlw 0 ;return xorwf keys,f ;store key value movlw 0x64 ;a fairly long delay will movwf scratch ;prevent key bounces Key_delay movlw 0xFF call Delay decfsz scratch goto Key_delay btfss keys,2 ;test "minutes" button goto Inc_mins btfss keys,1 ;test "tens" button goto Inc_tens btfss keys,0 ;test "hours" button goto Inc_hours retlw 0 ;must be a glitch. yeah, right! ;-------- ; increment ten minutes ;-------- Inc_tens movlw 0x0A movwf scratch ;scratch has ten Inc_tens_loop call Inc_mins decfsz scratch goto Inc_tens_loop ;another minute added retlw 0 ;-------- ; increment one hour ;-------- Inc_hours movlw 0x12 xorwf hours,w btfsc STATUS,Z goto Inc_hours_12 movlw 0x07 ;this part gets a little sloppy addwf hours,w movlw 0x07 btfss STATUS,DC movlw 1 addwf hours,f retlw 0 Inc_hours_12 movlw 0x01 movwf hours retlw 0 ;-------- ; increment the time based on flags,1 as sent by interrupt routine ; Inc_mins loop also used by time-setting routine ;-------- Keep_time btfss flags,1 ;the minutes flag retlw 0 ;not this time bcf flags,1 ;clear the minutes flag Inc_mins movlw 0x07 ;start incrementing time addwf minutes,w ;add 7 minutes into w btfsc STATUS,DC ;did adding 7 cause digit carry? goto Sixty_mins ;then test for an hour change incf minutes ;otherwise add 1 for real retlw 0 ;and go back Sixty_mins movwf minutes ;save the minutes movlw 0x60 ;test for 60 xorwf minutes,w ;are minutes at 60? btfss STATUS,Z retlw 0 ;no? go back clrf minutes ;otherwise zero minutes goto Inc_hours ;and increment hours ;-------- ; End of subroutines ; Program starts here ;-------- Start call Ram_init ;set variables to nice values call Port_init ;set port directions call Timer_init ;start timer based interrupt ;-------- ; Done initializing, start the endless loop. ;-------- ; Circle ;begin the big loop ; ;-------- ; detect falling edge on PORTA,4 to determine rotary index ; calculate rotation period and store in period_dup ; compare with working period(period_calc) and adjust if way different ;-------- call Check_index ;-------- ; check display state and change if needed ;-------- call Display_now ;-------- ; check keyboard and adjust time ;-------- call Check_keys ;-------- ; check minute flag and increment time if a minute has passed ;-------- call Keep_time ;-------- ; gentlemen, that's a clock, keep it rolling ;-------- goto Circle ;you heard the man, get going! end ;-------- ; end of file ;--------
