ultrasonic.1991
Member level 3
hi i designed a simple 4 pole touch key using ttp223 IC. i encountered a problem when using it. sometimes when i touch a key, another random key switches. and sometimes when i reset power, a key switches to a condition and never switches back after touching. i attached the 1 pole circuit and the power circuit. about the component with the picture of LED i should say that its a pcb pad connected to two back to back leds and a light guide which distributes light is placed over the leds. and a 4 mm glass is placed over the light guide. in the power circuit i used a 220 to 5v small smps.
what do you think the problem is?.
i found that there is something called snubber circuit which is a reisistor series with a capacitor parrallel with the contact pins of relay for suppressing exessive noise and also there is an option of optocoupler for isolation and suppressing noise. are these useful in my case ?
thanks in advance
thanks in advance
