Problem with the results of simulating diff. VCO at 0.15u
cmos_dude
Member level 5
Member level 5
VCO help
Hi All
I have designed a differential VCO at 0.15u tech. I simulated the design by gradually increasing the control voltage and got oscillations where the oscillating frequency is increasing with the increase in the control voltage.
but the oscillating swing decreases at low control voltages.
I have attached the simulation result pic.
Please look into and tell whether the simulation results are what they are supposed to be.
Any kind of inputs will be highly appreciated.
Regards
cmos dude
willyboy19
Full Member level 3
Full Member level 3
Re: VCO help
We can not give you any useful feedback without looking at your circuitry first -- it is needed to debug a problem in the design.
neoflash
Advanced Member level 1
VCO help
Normally, good question will result in good answers. Do you need junk answers?
gdhp
Full Member level 1
Re: VCO help
i think you can add a level shift at the output of VCO, such the output of vco will tuggled with 0 to vdd.
Added after 3 minutes:
cmos_dude
Member level 5
Member level 5
Re: VCO help
Hi All
I really apologise if my earlier post was not clear enough.
Here is the differential cell that I am using for my circuit. It is a ring oscillator design. I am also confused as to what should be the input voltage at the Vcp terminal in the differential cell. Presently I am keeping it at a constant voltage.
Regards
cmos dude
paulux
Full Member level 1
Re: VCO help
You can keep control voltage constant to see the oscillation. Maybe you can check whether the differential pair is out of saturation region or not.
