kokimisev
Newbie level 1
I have connected lpc2138 model in proteus throught UART0 connection with COMPIM component but it doesn't work so it doesn't send any character. it's connected like on the picture, and the code that I use is:
I use IAR kickstart 5.0 and the code above works.
Can anybody help me?
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 #include <includes.h> extern void TimeDelayUS(int uSeconds); /************************************************************************* * Function Name: UART0_Init *************************************************************************/ void UART0_Init( void ) { //UART0 Line Control Register (U0LCR) U0LCR_bit.WLS = 0x0; U0LCR_bit.SBS = 0; U0LCR_bit.PE = 0; U0LCR_bit.PS = 0x0; U0LCR_bit.BC = 0; U0LCR_bit.DLAB = 1; //Enable access to Divisor Latches. //UART0 Divisor Latch LSB Register (U0DLL) U0DLL = 0x12; //9600 baud (for 115200 use 0x0D) //UART0 Divisor Latch MSB Register (U0DLM) U0DLM = 0x00; //9600 baud (for 115200 use 0x00) //UART0 Line Control Register (U0LCR) U0LCR_bit.WLS = 0x3; //8 bit character length. U0LCR_bit.SBS = 0; //1 stop bit. U0LCR_bit.PE = 0; //Disable parity generation and checking. U0LCR_bit.PS = 0x0; //Odd parity. U0LCR_bit.BC = 0; //Disable break transmission. U0LCR_bit.DLAB = 1; //Disable access to Divisor Latches. //UART0 FIFO Control Register (U0FCR) U0FCR_bit.FCRFE = 1; //Enable both UART0 RX and TX FIFOs U0FCR_bit.RFR = 1; //Clear the UART0 RX FIFO. U0FCR_bit.TFR = 1; //Clear the UART0 TX FIFO. U0FCR_bit.RTLS = 0x0; //Set RX trigger level to 1 character. //UART0 Fractional Divider Register (U0FDR) U0FDR_bit.MULVAL = 0xC; //Baudrate generation pre-scaler divisor value. U0FDR_bit.DIVADDVAL = 0x1; //Baudrate pre-scaler multiplier value. //UART0 Interrupt Enable Register (U0IER) U0IER_bit.RDAIE = 1; //Enable the Received Data Available interrupt U0IER_bit.THREIE = 0; //Enable the Transmit Holding Register Empty interrupt U0IER_bit.RXLSIE = 0; //Enable the Receiver Line Status interrupt U0IER_bit.ABTOINTEN = 0; //Enable the End of Autobaud interrupt U0IER_bit.ABEOINTEN = 0; //Enable the Autobaud Timeout interrupt } /************************************************************************* * Function Name: UART0_TransmitString *************************************************************************/ void UART0_TransmitString( char *String ) { int CharPos = 0; //Character position inside the string. while( String[ CharPos ] ) { U0THR = String[ CharPos ]; TimeDelayUS(400); U0FCR_bit.TFR = 1; CharPos++; } } /************************************************************************* * Function Name: UART0_ISR *************************************************************************/ void UART0_ISR( void ) { if ( U0IIR_bit.IID == 0x2 ) { } } /************************************************************************* * Function Name: UART1_Init *************************************************************************/ void UART1_Init( void ) { //UART1 Line Control Register (U1LCR) U1LCR_bit.WLS = 0x0; U1LCR_bit.SBS = 0; U1LCR_bit.PE = 0; U1LCR_bit.PS = 0x0; U1LCR_bit.BC = 0; U1LCR_bit.DLAB = 1; //Enable access to Divisor Latches. //UART1 Divisor Latch LSB Register (U1DLL) U1DLL = 0x12; //9600 baud (for 115200 use 0x0D) //UART1 Divisor Latch MSB Register (U1DLM) U1DLM = 0x00; //9600 baud (for 115200 use 0x00) //UART1 Line Control Register (U1LCR) U1LCR_bit.WLS = 0x3; //8 bit character length. U1LCR_bit.SBS = 0; //1 stop bit. U1LCR_bit.PE = 0; //Disable parity generation and checking. U1LCR_bit.PS = 0x0; //Odd parity. U1LCR_bit.BC = 0; //Disable break transmission. U1LCR_bit.DLAB = 1; //Disable access to Divisor Latches. //UART1 FIFO Control Register (U1FCR) U1FCR_bit.FCRFE = 1; //Enable both UART1 RX and TX FIFOs U1FCR_bit.RFR = 1; //Clear the UART1 RX FIFO. U1FCR_bit.TFR = 1; //Clear the UART1 TX FIFO. U1FCR_bit.RTLS = 0x0; //Set RX trigger level to 1 character. //UART1 Fractional Divider Register (U1FDR) U1FDR_bit.MULVAL = 0xC; //Baudrate generation pre-scaler divisor value. U1FDR_bit.DIVADDVAL = 0x1; //Baudrate pre-scaler multiplier value. //UART1 Interrupt Enable Register (U1IER) U1IER_bit.RDAIE = 0; //Enable the Received Data Available interrupt U1IER_bit.THREIE = 0; //Enable the Transmit Holding Register Empty interrupt U1IER_bit.RXLSIE = 0; //Enable the Receiver Line Status interrupt U1IER_bit.ABTOINTEN = 0; //Enable the End of Autobaud interrupt U1IER_bit.ABEOINTEN = 0; //Enable the Autobaud Timeout interrupt } /************************************************************************* * Function Name: UART1_TransmitString *************************************************************************/ void UART1_TransmitString( char *String ) { int CharPos = 0; //Character position inside the string. while( String[ CharPos ] ) { U1THR = String[ CharPos ]; TimeDelayUS(400); U1FCR_bit.TFR = 1; CharPos++; } } /************************************************************************* * Function Name: UART1_ISR *************************************************************************/ void UART1_ISR( void ) { if ( U1IIR_bit.IID == 0x2 ) { } }
