problem with solder mask printing ?
Full Member level 4
egypt
hiii,
i use silk screen method for printing solder mask layer.
but i have problem. how i can matching pcb layout with solder mask layer?
pranam77
Advanced Member level 5
INDIA
Your question is not clear. You generate both by the same software and get it alligned 1:1 on the etched PCB and print on. If you need more details, you need to clarify your question in detail.
5282604
Full Member level 4
egypt
the solder mask layer and layout are 1:1
when i put pcb in silk sreen to print solder mask ! i can't aligned all pcb with silkscreen . alot of board solder mask print in wrong place on pcb i have error with matching silk screen with all pcb layout.
Full Member level 4
egypt
i ask about if some one in this forum use silk screen method. and my post deleted why :-(
cyberrat
Advanced Member level 3
In the sewers of the U.K.
Your solder mask is not misaligned, your silkscreen/legend is though.
To align it you need small crosses on your artwork external to the board.
These should be aligned with crosses on your bed, if you put small bits of pcb on the bed 9usually held on with tape) to slot the PCb into before silk screening it then they need marking up so the crosses in the screen align with the markings.
Once they are aligned you might put tape on the underside of the screen so no ink comes through the crosses.
Or - if your bed allows it you can shine a light through from underneath so that you can see through the PCB and align the screen.
