galib.tan
Newbie level 6
Hi everybody
Hope you all are fine.
I'm working on a forward converter which is giving me a lot of hassle. The required output voltage and current ratings are 16V and 2.5A. The switching frequency is 100 kHz with a duty cycle of 35%. This PWM is generated by a microcontroller and fed to the gate via an IR2110 and a gate drive transformer.
At first I used an 8 ohm NTC and 1A fuse and it worked though the voltage was greater than expected because I mistakenly added more turns on the secondary. After rewinding the circuit worked for several minutes then suddenly the fuse blew off. A number of fuses blew. The problem had gone using a 20 ohm NTC. The fuse was also changed to 5A. Then the mosfet got damaged (not burnt but G, D and S all short), the PWM was turned off in that case.
Then the mosfet was replaced and powered up again with PWM on, this time the NTC exploded and the reset winding diode got short. This diode got short several times before.
I'm new to power electronics. I don't understand if I'm doing anything wrong or missing something.
Please do help. Thanks in advance.
