[SOLVED] Problem with simple binary counter
gmish27
Member level 1
Member level 1
I am stuck at a problem that is taking lot of time for me to solve out. I wanna make a simple binary counter of 'n' digits. Now the code that has been provided in the book is given below to implement the same:
//code from book:
module sc #(parameter n=2)(
input clk,
input reset,
output [n-1:0] signal
wire [n-1:0] r_nxt;
reg [n-1:0] r_reg;
always@(posedge clk,posedge reset)
if(reset)
r_reg <= 0; //{n{1'b0}}
else
r_reg <= r_nxt;
assign r_nxt = r_reg + 1;
assign signal = r_reg;
endmodule
Well i did not follow it and wrote my own as below:
//my own code for the same problem:
input clk,
input reset,
output reg [n-1:0] signal
if(reset)
signal <= 0;
else
signal <= signal + 1;
endmodule
Firstly if anyone finds an error in my code, or any difference in the above two codes, then please tell me about it.
Secondly, I myself did not find any difference as with Xilinx simulator I am getting the same output for both of the codes. The corresponding Testbench file is given below:
//Generated testbench as HDL, the same used for both the codes
`timescale 1ns/1ps
module sctbw;
reg clk = 1'b0;
reg reset = 1'b0;
wire [1:0] signal;
parameter PERIOD = 200;
parameter real DUTY_CYCLE = 0.5;
parameter OFFSET = 100;
initial // Clock process for clk
begin
#OFFSET;
forever
begin
clk = 1'b0;
#(PERIOD-(PERIOD*DUTY_CYCLE)) clk = 1'b1;
#(PERIOD*DUTY_CYCLE);
end
end
sc UUT (
.clk(clk),
.reset(reset),
.signal(signal));
initial begin
// ------------- Current Time: 385ns
#385;
reset = 1'b1;
// ------------- Current Time: 585ns
#200;
reset = 1'b0;
// ------------- Current Time: 1385ns
#800;
reset = 1'b1;
// ------------- Current Time: 1585ns
#200;
reset = 1'b0;
// ------------- Current Time: 2385ns
#800;
reset = 1'b1;
// ------------- Current Time: 2585ns
#200;
reset = 1'b0;
// ------------- Current Time: 3385ns
#800;
reset = 1'b1;
// ------------- Current Time: 3585ns
#200;
reset = 1'b0;
// ------------- Current Time: 4385ns
#800;
reset = 1'b1;
// ------------- Current Time: 4585ns
#200;
reset = 1'b0;
end
endmodule
Thirdly, the main problem, at a reset trigger I expect a zero output from the signal line for just one clock cyle.
For the first reset trigger at 385ns the ouput stands on my expectations but scenario changes with the other triggers. At simulation timings of 4385ns, 3385ns, 2385ns, 1385ns I am getting a zero output signal for two clock cyles!!!
So please tell me the mistake and how to correct it cos i want a zero signal ( a restart) for just one clock cycle.
dcreddy1980
Full Member level 5
Full Member level 5
Munich, Germany
There is no problem with the code.
Its the testbench which causes your o/p to stay at "0" for two clock cycles. The counter has wrapped to "0" before you have applied the new reset and that causes the o/p to stay for two clock cycles.
Make the below change for reset trigger :
#1000;
Reactions: gmish27
    gmish27
gmish27
Member level 1
Member level 1
Oh ho, such a silly mistake and i did not notice. Was searching for the reason of the fault deliberately. Thankyou sir for ur help :)
