Veronika
Member level 2
When I was creating a new Decal (part) in PADS Layout software, I have set "All Layers" in the Drafting Properties for the component's outline. Is it correct? So when I type "z 26" in order to see only the Silkscreen Top, this outline appears. So it works in PCB Decal Editor. But when I use this component in the PCB Layout design and type "z 26", no outline appears for that component. How this could be? What should I do to have the component's outline on the Silkscreen Layer?
By the way, what is the difference between "Silkscreen Top" and "Assembly Drawing Top" layers?
