Problem with shared libraries when opening ICFB
Blilix
Member level 1
I copy my old ic5033, whole directory installed in RH8 to SUSE and setup .tcshrc already. When I run "icfb&" i got this message error :
"/usr/cad/cadence_ic5033/tools/dfII/bin/icfb.exe: error while loading shared libraries: libCdsXmotif.so.2: cannot open shared object file: No such file or directory"
Does anyone know how to solve this problem?
to type fontstruct ic5033
hi hr_rezaee
I can solve this problem already after I configure it. Thanks for your suggestion.
However, I have another problem. How can I set my plotter so I can plot the .ps files or pdf files of my schematic or layout? I use the NCSU_CDK 1.5 and copy the cdsplotinit.sample--> .cdsplotinit at my working folder. When I run "icfb", it shows the log like this:
Loading /usr/cad/cadence_ic5033/tools/plot/.cdsplotinit
*WARNING* No plotters are defined in the configuration database
Loading hspicei.cxt
Warning: Cannot convert string "-adobe-helvetica-medium-r-normal--0-100-75-75-p-0-iso8859-1" to type FontStruct
How can I solve these problems?
PS. I run ic5033 on SUSE10
thanks in advance
libcdsxmotif.so.2
Those are just warnings. You probably don't have to worry.
Re: How to solve this?
Anyway, do you know how to solve it ? Because of these warning, I can not use the plot function in my ic5033.
