Problem with RS-232 communication between RMS-DC converter and A/D converter
saurav_sdpl
Full Member level 3
Iam doing a project for datalogging of some AC and DC parameters.
Using RS-232 comm.
MCP506(multiplexer) gives the multiplexed o/p to RMS-DC converter and then to A/D converter, and the corresponding count is displayed on pc.
But the settling time of rms to dc converter is more , because of which there are error in ac signal reading.
How can i rectify this problem.
Microcontroller used is AT89c52.
serial port communication is polling based.
if i increase the delay between reading of two signals, whether this will help, and whether this wld effect the rate for comm.
Plz help
Re: rs232 comm
More than what?
PC polling AT89c52?
What is your polling rate, and what is your Baudrate?
Re: rs232 comm
settling time of rms to dc converter is more than that of multiplexer.
Baud rate : 4800bits per second
polling rate:224ms
Re: rs232 comm
Hai,
Will u pls post ur Circuit or Block Diagram, may be helpful to understand ur problem
Thanks
