problem with rotary encoder
mohamed.elsabagh
Full Member level 2
I am using a rotary encoder with a switch button, I am using c8051f340 microcontroller to detect the encoder movement on external interrupt, but the problem is that sometimes the code detect the clock wise movement as anticlock wise and vice versa i don't know what is the wrong, is there a problem with the rotary encoder itself.
mohamed.elsabagh
Full Member level 2
void External_Interrupt1() interrupt INTERRUPT_INT1
// the interrupt is on negative edge trigger of B
if(encoder_state != encoder_unknown) ///// The last state of the encoder is not yet read by other layers
return;
else
//// This code applies only when B is on interrupt
if((ENCODER_PORT & ENCODER_A_MASK) == 0x00) /// check wether A is 0 or 1
encoder_state = encoder_CW;
else
encoder_state = encoder_CCW;
FvM
Super Moderator
Staff member
Bochum, Germany
To get full encoder resolution, you'll want to process all edges of A and B output. PIC port change interrupt is a good way to implement it. For moderate encoder speeds, a fast timer interrupt can do as well.
I wonder about the purpose of huge 100 nF capacitors parallel to the encoder switches. They are causing unwanted delays and large discharge currents that stress the switches.
alexxx
Greece
You must implement a state machine to get direction and speed. Read wikipedia's article especially the "Incremental rotary encoder" part. Both state machines for the two directions are shown in the two tables there.
https://en.wikipedia.org/wiki/Rotary_encoder
Make sure that the pin change interrupt has a high priority, otherwise you will lose counts and this will drive your algorithm to fault conclusions.
Also it is common practice to use schmitt trigger gates in series with the A, B signals.
