Problem with printing results of PCB in Protel99SE
planet1
Newbie level 3
Protel99SE
Hi, I have a problem with my Protel 99 SE. When I print a PCB, dimension on the paper are not same with the dimension on the PC.
Rectangular 100x100(mmxmm) on the PC adequate on 104x104(mmxmm) on the paper.
Does anybody knows how can I solve this problem?
binu G
Advanced Member level 2
Bangalore
Protel99SE
Check your Scale setting you used durring printing.
if it is 1:1 then some printers have some print offset.
my it an offset in that case.
binu g
House_Cat
USA
Re: Protel99SE
In addition to what Binu G said above, make sure that you have "standard print" selected in the printer properties. If you select "whole board on one page" the printout is scaled to fit the page, and will not be a true 1:1 printout.
arcaphill
Member level 5
Protel99SE
No one is best, it's depend on your requirment!
I used Protel, PowerPCB & Cadence, each one has its own characteristic. Protel is easy to learn, PowerPCB is uesd for 4-8 layers PCB layout, if you want more layers PCB, Cadence is a good choice!
terka
Re: Protel99SE
Hi men...
I want to learn to use eagle pcb, but protel99 is better??
Please help me in this issue.....
some reference??
Thank you
diodo
Newbie level 5
Re: Protel99SE
Protel 99se is good for Windows ME but
Protel DXP2004 is better in windows XP
