Problem with Power nets
Mariammm
Junior Member level 1
Hi ,
I have an inquiry regarding the power nets in power planning step.
when I write get_nets VDD command after derive_pg_connection command, I get this warning message "Warning: No net objects matched 'VDD' (SEL-004)"
So, I can't understand what is the reason for this warning message?!
I attached below a copy of the command execution results.
Thanks in advance
icc_shell> derive_pg_connection -power_net VDD\
-ground_net VSS\
-power_pin VDD\
-ground_pin VSS
Information: connected 18799 power ports and 18799 ground ports
icc_shell> get_nets VDD
dick_freebird
Advanced Member level 5
USA
Are you sure that the power nets should be named
"VDD" and "VSS"? In the tools and PDKs I have used,
"vdd!" and "vss!" (global nets, for inherited connections)
or "vdd", "vss" (for direct-wired schematic design style)
are much more commonly used.
You might inspect one of the logic cells and see
what they think their power pins are called.
oratie
Full Member level 6
Try such command "get_nets -all VDD"
ThisIsNotSam
VDD and VSS are typical names in digital physical design. vdd!/vss! are more of a custom designer thing.
Mariammm
yes, I inspected them and their power pins are called VDD and VSS.
Mariammm
icc_shell> get_nets -all VDD
{VDD}
This is the result of executing the command. So, does this mean that the Power nets are properly connected?
oratie
Full Member level 6
No, it only means, that you have power (or ground) net VDD in the design. Option -all include power/ground nets in get_nets result printing.
Information: connected 18799 power ports and 18799 ground ports - This means, that you have VDD/VSS connected to pins.
Mariammm
Okay, thank you so much.
LaTeX Commands Quick-Menu:
