blinkyu
Newbie level 1
I tried PIC18F46K20 C18 Lessons
1 lesson was successful- Build succeeded.
But I still have a problem- LED is not light on. Why?
I did all, what was in C18 lessons instruction, programmed corectly, but I dont see the light. (I tried to load the demo of Pong, it was working).
The second problem is with blinking LED.
Here is the code: (default)
//Software License Agreement
//The software supplied herewith by Microchip Technology
//Incorporated (the "Company") is intended and supplied to you, the
//Company’s customer, for use solely and exclusively on Microchip
//products. The software is owned by the Company and/or its supplier,
//and is protected under applicable copyright laws. All rights are
//reserved. Any use in violation of the foregoing restrictions may
//subject the user to criminal sanctions under applicable laws, as
//well as to civil liability for the breach of the terms and
//conditions of this license.
//THIS SOFTWARE IS PROVIDED IN AN "AS IS" CONDITION. NO WARRANTIES,
//WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT NOT LIMITED
//TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
//PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. THE COMPANY SHALL NOT,
//IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL OR
//CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.
// PIC18F46K20 Starter Kit Lesson 2 - Blink LED
// This lesson blinks LED 7 on the demo board by using a delay and
// loop.
// * See included documentation for Lesson instructions *
/** C O N F I G U R A T I O N B I T S ******************************/
#pragma config FOSC = INTIO67, FCMEN = OFF, IESO = OFF // CONFIG1H
#pragma config PWRT = OFF, BOREN = SBORDIS, BORV = 30 // CONFIG2L
#pragma config WDTEN = OFF, WDTPS = 32768 // CONFIG2H
#pragma config MCLRE = ON, LPT1OSC = OFF, PBADEN = ON, CCP2MX = PORTC // CONFIG3H
#pragma config STVREN = ON, LVP = OFF, XINST = OFF // CONFIG4L
#pragma config CP0 = OFF, CP1 = OFF, CP2 = OFF, CP3 = OFF // CONFIG5L
#pragma config CPB = OFF, CPD = OFF // CONFIG5H
#pragma config WRT0 = OFF, WRT1 = OFF, WRT2 = OFF, WRT3 = OFF // CONFIG6L
#pragma config WRTB = OFF, WRTC = OFF, WRTD = OFF // CONFIG6H
#pragma config EBTR0 = OFF, EBTR1 = OFF, EBTR2 = OFF, EBTR3 = OFF // CONFIG7L
#pragma config EBTRB = OFF // CONFIG7H
/** I N C L U D E S **************************************************/
#include "p18f46k20.h"
#include "delays.h"
/** D E C L A R A T I O N S *******************************************/
void main (void)
TRISD = 0b01111111; // PORTD bit 7 to output (0) ; bits 6:0 are inputs (1)
while (1)
LATDbits.LATD7 = ~LATDbits.LATD7; // toggle LATD
Delay1KTCYx(50); // Delay 50 x 1000 = 50,000 cycles; 200ms @ 1MHz
And in a result:
Release build of project `C:\Lessons\PIC18F46K20 Starter Kit Lessons\02 Blink LED\02 Blink LED.mcp' started.
Language tool versions: mpasmwin.exe v5.35, mplink.exe v4.35, mcc18.exe v3.35
Sat May 29 21:48:36 2010
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\Lessons\PIC18F46K20 Starter Kit Lessons\02 Blink LED\02 Blink LED.o".
Clean: Done.
Executing: "C:\MCC18\bin\mcc18.exe" -p=18F46K20 "02 Blink LED.c" -fo="02 Blink LED.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\MCC18\bin\mplink.exe" /l"C:\MCC18\lib" "..\..\..\Users\Igor\Desktop\18f46k20.lkr" "02 Blink LED.o" "C:\MCC18\lib\p18F46K20.lib" /u_CRUNTIME /z__MPLAB_BUILD=1 /o"02 Blink LED.cof" /M"02 Blink LED.map" /W
MPLINK 4.35, Linker
Copyright (c) 1998-2010 Microchip Technology Inc.
Error - could not find definition of symbol 'Delay1KTCYx' in file './02 Blink LED.o'.
Errors : 1
Link step failed.
Release build of project `C:\Lessons\PIC18F46K20 Starter Kit Lessons\02 Blink LED\02 Blink LED.mcp' failed.
Sat May 29 21:48:37 2010
BUILD FAILED
Please help me.
Thanks.
// loop.
#include "delays.h"
void main (void)
while (1)
And in a result:
Clean: Done.
MPLINK 4.35, Linker
Errors : 1
Link step failed.
BUILD FAILED
Please help me.
Thanks.
