Problem with Perl script that creates directories with names
vlsi_fanatic
Junior Member level 1
Help with perl
i am new to perl. I got a problem. I am writing a script to create a
directory whose name will be generated in the script. for example one
of the directory name I need to create will be 9.1.3C I am getting
this value in a variable ($dirname) and I am using
print `mkdir C:/perl/$dirname` command to create it. Since the value
includes a Charecter perl is giving me syntax error. If the value is
just 9.1.3 the print line is working fine. But with that charecter at
the end I am getting problems. Can anyone solve my problem?
Thanks
nand_gates
Advanced Member level 3
Re: Help with perl
Try this one instead
system("mkdir C:/perl/$dirname");
Hope this helps!!
vlsi_fanatic
Re: Help with perl
again I am getting the same error
jammed
Newbie level 3
Re: Help with perl
make sure your directory name is enclosed in quotes.
$dirname = "9.1.3C";
hope this helps.
disney
Member level 1
Re: Help with perl
have it in quotes
kovalja
Junior Member level 2
Re: Help with perl
when I see your code, I'm really a little bit confused. Shouldn't you use back-slash instead of slash in Win directory path?
Let me know if windows changed the command line behaviour :)
BTW. If you want to create the directory structure similar you presented, try this:
system( "mkdir C:\\perl\\$dirname" );
HTH,
kovalja
vlsi_fanatic
Re: Help with perl
HTH,
kovalja
Windows didn't change the command line behavior. In this way you don't need to escape the backslash in the path. Try using it. It works.
Added after 1 minutes:
hope this helps.
If I put it in Quotes it works.
Thanks.
