Marios91
Junior Member level 3
- Joined
- Mar 25, 2015
- Messages
- 28
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Location
- Kalamata
- Activity points
- 209
I was assigned the project of designing a patch antenna with the following specs:reasonant freq of 2.4 GHz and 500 MHz Bandwidth(Τhe S11 should be under -5 Db).I have calculated the patch and the feeder line dimensions and designed the layout in Momentum.When i simulate the Antenna without the Groundplane i get the desired results.How is this possible?I mean you need a Groundplane to get your Antenna working.If i put a Groundplane in the layout the system won't work.Moreover are there any tips on how i can choose the dimensions and the position of the grounplane?
