Problem with output stage of a class D amplifier
diemilio
Full Member level 6
Framingham, MA
Hi everyone. I'm trying to design a high efficiency output stage for an audio amplifier. I want to keep my design simple so I found this class D amp (attached circuit) on the web but it seems to me that I'm missing something here cause if you notice the LC filter is used to get the original audio wave (in this case the sine wave) from a PW modulated signal, so at resonace the capacitor will act as very low impedance making a high current (very high) flow through it making my efficency 0!!!.
How can I modify my circuit to get the supposed 90% efficiency of a class D amp???
Thanks for your help,
diemilio
bunalmis
Full Member level 5
Ireland
Re: Output stage
Gate source capacity of MOS large therefore you need good mos driver.
diemilio
Full Member level 6
Framingham, MA
Re: Output stage
Could you please give me MOS references??
Verba
Member level 5
Output stage
C3 is too big, i think you should take it 100nF-1000nF.
Now you get LPF at 1/(2piR4C3)=160Hz
diemilio
Full Member level 6
Framingham, MA
Re: Output stage
But shouldn't my fliter be at 1kHz to let the average vale of the PW modulated signal (which is the same frequency of the sine input signal) pass???
Isn't the cutoff frequency 1/(2*pi*L*C)???
Verba
Member level 5
Re: Output stage
diemilio,
the cut off frequency will be 1/(2pi√(LC)), but that is if Rload>>1/sC (infinite load)
I gave you an aproximate cutoff frequency for L=0, and it's too low, within audio frequency band.
You must move it at least to 20-30 KHz
    diemilio
aborigini
Junior Member level 2
Output stage
Yes.. the low pass filter must be at least 20 or 30khz to allow audio signal.
The output stage need to be very very large,.. you need buffer for that.
Vamsi Mocherla
Advanced Member level 1
Re: Output stage
diemilio,
When you said that at resonant frequency, the cap is a short circuit to gnd. But the inductor will have a very high impedance and hence can limit the current. In fact, it is the inductor which actually controls the ripple in the current. The ripple is the high frequency current.
Also, if you are designing a Class D amplifier, you also can take care of the ripples in the voltages/currents by establishing a feedback loop.....
I hope that I am clear
    diemilio
Kral
USA
Re: Output stage
diemilio,
You want to keep the resonant frequency of the LC filter well above the input signal frequency (1KHz). The LC filter must be designed so that it provides adequate attenuation at the reference triangle wave frequency. However, in your case, the reference triangle frequncy is the same as the input signal frequncy. 1/(.5mS + .5ms) = 1 !KHz. It must be much higher than this for the amplifier to work properly. Typically, the reference frequency would be at least 10X the highest input signal frequency.
Regards,
Kral
bunalmis
    diemilio
diemilio
Full Member level 6
Framingham, MA
Re: Output stage
Thanks everyone for your help.
I could finally solve one of my problems!!!
diemilio
