problem with orcad 9.2
u04f061
less than 2 connections at node
my orcad capture is giving me a stupid error message on a very simple circuit diagram containing only one op-amp.the file in word ritch text is attatched below.
this contain scematic diagram and error message.
the error message is also given below
**** INCLUDING k-SCHEMATIC1.net ****
* source K
V_V2 0 N000035 15
V_V1 N00623 0
+SIN 0 1m 3 0 0 0
R_R1 N00623 N000031 10k
V_V3 N000033 0 15
R_R2 N01082 N01030 100k
R_R3 0 N01030 100k
**** RESUMING k-SCHEMATIC1-h.sim.cir ****
.END
ERROR -- Less than 2 connections at node N000031
ERROR -- Less than 2 connections at node N01082
note:****************************************
i have orcad 9.2 by cadence
pspice less than 2 connections at node
that is because you didn't make R1,R2 and U1 connecting properly by wire.
suggest you moving them away each others and re-connecting exactly at pin point.
Reactions: K2d2
    u04f061
    K2d2
error -- less than 2 connections at node
ok i did this but the green disc and warning was still with u1.
how ever the simulation ran and did't produce accurate result.it produced output less than input
less than 2 connections at node pspice
that is because the U1 you chose was not a pspice model, it is just a symbol for schemadic drawing. you should choose pspice model in \capture\library\pspice
pspice error less than 2 connections at node
ok this is now working but the output is now clamped version of what it should be
plz have a look at attatchment
error_ _is less then 2 connection
From my point of view, the simulation is correct, I guess your question was wondering the 4.1 mVDC product at output, it was due to one of OPA's characteristic, input offset voltage.
