Problem with My circuit
tam_yehia
Newbie level 3
Dear all. I found the attached circuit on the internet and i'm trying now to implement it. But I have a question here. Regrading the 7-segment display inputs from IC2 (75492) I want to know to which pin in the 7-segment display I have to conect this input. Regards
chuckey
Advanced Member level 5
Southampton and holiday cottage in Wensleydale (UK
To make a display come on the left hand pins of the 75492 must be at a 1. This IC makes each display come on it turn (or all together!). The top chip drives each LED within the display. Some where there should be current limiting resistor.
Frank
tam_yehia
Newbie level 3
Thanks Frank. I mean the output of the second IC-75492 (pins 2,6,7,9 and 13) all of them must be connected to the 7-segment displays (my question is to which pin in the 7-segment display must I connect these 5 outputs?).
vinoth8051
Full Member level 3
Delhi, Kanpur, Madurai, India
Connect to pin 3 and 8 of the 7-segment display. kindly see the image.
Hope this helps..
FvM
Super Moderator
Staff member
Bochum, Germany
Have you seen the 7-segment display in your crystal ball or are you just guessing?
There are about 10 different 7-segment pinouts in use. You'd either refer to a known type or figure out the pinout by using a multimeter.
