Problem with MicroCode Studio
The Puma
Full Member level 2
I will try the free version of microcode studio
But i can't install it
The following error occuring"
16 Bit windows subsystem
C:\WINDOWS\SYSTEM32/AUTOEXEC.NET. The system fil is not suitable for running MS-DOS and Microsoft Windows applications. Choose "close' to terminate the application
Anybody else has this message
I use Windows XP SP2
Cluricaun
Advanced Member level 2
Hi
Try first to clean temp catalog, Start - Run - %temp% and remove the files. If they are in use reboot first.
The problem is most likely that something tampered with one or more of these files:
Config.nt Autoexec.nt Command.com
From DOS paste following lines one by one:
%CDROM%:\i386\config.nt_ c:\windows\system32\config.nt
%CDROM%r:\i386\autoexec.nt_ c:\windows\system32\autoexec.nt
%CDROM%:\i386\command.co_ c:\windows\system32\command.com
At %CDROM% you have to write the path to your CD were you put XP CD.
Reboot and retry, this is a "common" error and not related to certain SW.
Good luck
The Puma
Full Member level 2
It works Cluricaun,
Thnx for your fast help
