saikiran@ees
Member level 3
Hi Friends,
I am using dsPIC30F5011 micro controller and I want to control dip switches through io expander that means on and off the switches by detecting the range.In between dip switch and io expander, I connected UNL2803 driver IC.
Basically i tested it for LED on/off but it is also not working.So give me suggestions,for led's on/off using io expander with i2c protocol.
Thanks and Regards,
M SAI KIRAN.
Thanks and Regards,
M SAI KIRAN.
