Problem with Live Design Evaluation Board
Lykos1986
Member level 4
I have the new live design Evaluation Board (Xilinx Spartan 3S1000). I use the Altium DXP 2004 SP2 program and not the Altium Designer 6. I have got the Xilinx ISE 7.1i (download version). When I select “Device management ant connection” from the program it shows me
“Unsuported version of Xilix ISE”
What I have to do???
Help please
Hi!
Search for the file "XilinxVersions.txt" within your installation directory.
Then add a line for your ISE 7.1 Version. The syntax of the file is easy to understand.
Regards
MadDog
    Lykos1986
Thanks GeneralMadDog. There is no problem any more :D
PS
Do you know any place for download the schematics of the Evaluation Board (pin connections etc) ? I have downloaded the schematics from this link
but is for Xilinx Spartan 3S400 and not for 3S1000. Little help please :cry:
i think you can find it in the Altium Designer 6 CD.
you might also need to have a different constraints file for the new board because DXP 2004 doesnt have the constraints file of the 3S1000 board.
Basically I want to use the Evaluation Board with Xilix ISE 7.1i and not with Altium Designer 6. But I have to have the schematics.
If any one has the Altium Designer 6 I just want to post me some ware the "C:\Altium Designer 6\Examples\LiveDesign Evaluation Board" folder or the entire “Examples” folder of Altium Designer 6 for downloaded it
Or just post me some ware the new schematics of Live Design Evaluation Board (Xilinx Spartan 3S1000)
