Problem with LinkList in C++ Programming:
bhattaroshan
Member level 1
When i write this it works fine
#include<iostream>
#include<conio.h>
#include<stdio.h>
using namespace std;
typedef struct stack
        int num;
        stack *lpnext;
stack *head=0;
void push_me_back(int num)
     stack *tmp,*tmp2;
      tmp=new stack;
      tmp->num=num;
      tmp->lpnext=0;
     if(head==0)
       head=tmp;
     else
       tmp2=head;
       while(tmp2->lpnext)
        tmp2=tmp2->lpnext;
       tmp2->lpnext=tmp;
int main()
    push_me_back(10);
    push_me_back(20);
    push_me_back(30);
    cout<<head->lpnext->num;
    getch();
    return 0;
But when i make slight change in code as follows code is not working what is the difference. Is there anything difference in the code:
#include<iostream>
#include<conio.h>
#include<stdio.h>
        int num;
        stack *lpnext;
stack *head=0;
     stack *tmp,*tmp2;
      tmp=new stack;
      tmp->num=num;
      tmp->lpnext=0;
     if(head==0)
       head=tmp;
     else
       tmp2=head->lpnext; //made changes here
       while(tmp2)  //made changes here
        tmp2=tmp2->lpnext;
       tmp2=tmp; //made changes here
int main()
    push_me_back(10);
    push_me_back(20);
    push_me_back(30);
    getch();
    return 0;
#include<iostream>
#include<conio.h>
#include<stdio.h>
        int num;
        stack *lpnext;
stack *head=0;
     stack *tmp,*tmp2;
      tmp=new stack;
      tmp->num=num;
      tmp->lpnext=0;
     if(head==0)
       head=tmp;
     else
       tmp2=head->lpnext; //made changes here   [COLOR="#FFD700"]since the pointer has null stored in it it flags an error[/COLOR]
       while(tmp2)  //made changes here[COLOR="#FF0000"]there is null in tmp2 and so the segment is omitted [/COLOR]
        tmp2=tmp2->lpnext;
       tmp2=tmp; //made changes here[COLOR="#FF0000"]as the above conditions failed this is also flagged as an error [/COLOR]
int main()
    push_me_back(10);
    push_me_back(20);
    push_me_back(30);
    getch();
    return 0;
my corrections are in colour hope it helps
thanks for your reply
if so then why does the first code that i posted runs without an error
even tmp2->lpnext is null pointer.......
there you have defined the pointer
there is no memory allocated to the pointer in your program
that is the reason for the error to be flagged
remember that pointer gets defined only when memory is assigned to it
Let me write another example exactly as above but with pointer to integer.
#include<iostream>
#include<conio.h>
#include<stdio.h>
int main()
    int *b,*a,*c;
    c=new int;
    b=NULL; //it is not pointed any where
    a=b;  //according to you this is wrong
    while(a); //this is also wrong according to you
    a=c; //this is also wrong
    *a=10; //but all these works well
    getch();
    return 0;
If what you told is correct why does this code run well?
I might not be understanding linklist? If you have any tutorials or site, or anything please help me out.
Thanks for you reply.
try out a book by NV publications for data structures and stuff like that
also go for pearson publication's book they are worth trying
the difference in these coding is simple int is a default data type
whereas you are using a abstract datatype in list that makes a huge difference in the applications of them in the programs
