Problem with license in IC615
kokabanga
Member level 5
Member level 5
Hi all,
I have installed IC615 on Ubuntu 10.04.
How ever when I execute
/usr/eda/IC615/tools/bin/lmgrd -c /home/ramani/IC615/license.dat
I see that the license has not been configured correctly.
There is some problem with this verisityd.
Anyone seen this error before?
Please help!
16:50:08 (lmgrd) Please Note:
16:50:08 (lmgrd)
16:50:08 (lmgrd) This log is intended for debug purposes only.
16:50:08 (lmgrd) In order to capture accurate license
16:50:08 (lmgrd) usage data into an organized repository,
16:50:08 (lmgrd) please enable report logging. Use Acresso Software Inc.'s
16:50:08 (lmgrd) software license administration solution,
16:50:08 (lmgrd) FLEXnet Manager, to readily gain visibility
16:50:08 (lmgrd) into license usage data and to create
16:50:08 (lmgrd) insightful reports on critical information like
16:50:08 (lmgrd) license availability and usage. FLEXnet Manager
16:50:08 (lmgrd) can be fully automated to run these reports on
16:50:08 (lmgrd) schedule and can be used to track license
16:50:08 (lmgrd) servers and usage across a heterogeneous
16:50:08 (lmgrd) network of servers including Windows NT, Linux
16:50:08 (lmgrd) and UNIX. Contact Acresso Software Inc. at
16:50:08 (lmgrd) www.acresso.com for more details on how to
16:50:08 (lmgrd) obtain an evaluation copy of FLEXnet Manager
16:50:08 (lmgrd) for your enterprise.
16:50:08 (lmgrd)
16:50:08 (lmgrd) -----------------------------------------------
16:50:08 (lmgrd)
16:50:08 (lmgrd)
16:50:08 (lmgrd) FLEXnet Licensing (v11.7.0.0 build 73797 i86_lsb) started on proton.ece.unm.edu (linux) (10/12/2009)
16:50:08 (lmgrd) Copyright (c) 1988-2009 Acresso Software Inc. All Rights Reserved.
16:50:08 (lmgrd) US Patents 5,390,297 and 5,671,412.
16:50:08 (lmgrd) World Wide Web: **broken link removed**
16:50:08 (lmgrd) License file(s): /home/ramani/IC615/license.dat
16:50:08 (lmgrd) lmgrd tcp-port 5280
16:50:08 (lmgrd) Starting vendor daemons ...
16:50:08 (lmgrd) Started cdslmd (internet tcp_port 42530 pid 2038)
16:50:08 (lmgrd) Started verisityd (internet tcp_port 41705 pid 2039)
16:50:08 (lmgrd) Started verplex (internet tcp_port 38985 pid 2040)
16:50:08 (lmgrd) license daemon: execute process failed: (./verisityd or /usr/eda/IC615/tools/bin/verisityd) -T proton.ece.unm.edu 11.7 3 -c /home/ramani/IC615/license.dat
16:50:08 (lmgrd) license daemon: system error code: No such file or directory
16:50:08 (lmgrd) verisityd exited with status 45 (Child cannot exec requested server)
16:50:08 (lmgrd) Please correct problem and restart daemons
16:50:08 (lmgrd) license daemon: execute process failed: (./verplex or /usr/eda/IC615/tools/bin/verplex) -T proton.ece.unm.edu 11.7 3 -c /home/ramani/IC615/license.dat
16:50:08 (lmgrd) verplex exited with status 45 (Child cannot exec requested server)
16:50:08 (cdslmd) FLEXnet Licensing version v11.7.0.0 build 73797 i86_lsb
16:50:08 (cdslmd) WARNING Set environment variable cdslmd_ENH_RECORDS=1 to enable ENH records usage logging enhancements
16:50:08 (cdslmd) Feature 111 is not enabled yet
