Problem with Li-Ion battery charger design using a buck converter
supersonic_ab
Junior Member level 2
hi,
I am making a Li ion battery charger and I am using a buck converter. The switching of the buck converter is done using a PMOS IRF9540 which in turn is connected to BC547 and then this BC547 is switched using Atmel Tiny13 using PWM. I am not getting the desired output... If any one could figure out the problem it will be of great help...
Thanks in advance
neoaspilet11
Full Member level 5
Cebu, Philippines
batter charger
I would suggest you use single chip Li ion charger. Its simple and you need only one control line to your MCU.
There are a lot out there. Im using Microchip's MCP3811
supersonic_ab
Re: battery charger
hey thanks for the reply and I am doing it as a project under a teacher as my internship and I need to work accordingly...
Thanks again...
supersonic_ab
Re: batter charger
hey,
can anyone tell me that what is the peak to peak voltage at the output of the buck converter... I am getting the spikes in the voltage... I have used enough capacitance to reduce that spike but there is no effect... any other possible reason for the spikes??
Thanks in advance
D_A_V_E
Member level 5
batter charger
Could you post the schematic please!
