// With help from the following website:
// [I]**broken link removed**[/I]
//Definitions
DEF DB4 0
DEF DB5 1
DEF DB6 2
DEF DB7 3
DEF EN 4
DEF RS 5
DEF RW 6
//Load 0 to Accumulator
LOAD 0
$Main
CALL $INIT_LCD
CALL $CLEAR_LCD
RAMWRT 3 DAT 'H'
CALL $WRITE_TEXT
RAMWRT 3 DAT 'E'
CALL $WRITE_TEXT
RAMWRT 3 DAT 'L'
CALL $WRITE_TEXT
RAMWRT 3 DAT 'L'
CALL $WRITE_TEXT
RAMWRT 3 DAT 'O'
CALL $WRITE_TEXT
RAMWRT 3 DAT ' '
CALL $WRITE_TEXT
RAMWRT 3 DAT 'W'
CALL $WRITE_TEXT
RAMWRT 3 DAT 'O'
CALL $WRITE_TEXT
RAMWRT 3 DAT 'R'
CALL $WRITE_TEXT
RAMWRT 3 DAT 'L'
CALL $WRITE_TEXT
RAMWRT 3 DAT 'D'
CALL $WRITE_TEXT
$READ_2_NIBBLES
BITSET EN
IOWRT ACC
IOREAD
RAMWRT 4
BITCLR EN
IOWRT ACC
BITSET EN
IOWRT ACC
IOREAD
BITCLR 7
BITCLR 6
BITCLR 5
BITCLR 4
RAMWRT 5
BITCLR EN
IOWRT ACC
RAMREAD 4
SHLE
SHLE
SHLE
SHLE
RAMWRT 4
RAMREAD 4
ADD RAM 5
RAMWRT 2
RETURN
$WRITE_2_NIBBLES
RAMREAD 3
BITSET EN
IOWRT ACC
BITCLR EN
IOWRT ACC
RAMREAD 3
ROL
ROL
ROL
ROL
BITSET EN
IOWRT ACC
BITCLR EN
IOWRT ACC
RETURN
$WAIT_LCD
BITCLR RS
IOWRT ACC
BITSET RW
CALL $READ_2_NIBBLES
RAMREAD 2
BITTST 7
JUMP IFNOT ZZERO $WAIT_LCD
BITCLR RW
IOWRT ACC
RETURN
$INIT_LCD
BITCLR RS
IOWRT ACC
BITCLR RW
IOWRT ACC
BITCLR EN
IOWRT ACC
BITSET EN
IOWRT ACC
OR 0x20
IOWRT ACC
//MOV DATA,#28h
BITCLR EN
IOWRT ACC
CALL $WAIT_LCD
RAMWRT 3 DAT 0x20
//MOV A,#28h
//Here writing to RAM is needed!!!
CALL $WRITE_2_NIBBLES
CALL $WAIT_LCD
//MOV A,#0Eh
RAMWRT 3 DAT 0x0E
CALL $WAIT_LCD
//MOV A,#06h
RAMWRT 3 DAT 0x06
CALL $WAIT_LCD
RETURN
$CLEAR_LCD
BITCLR RS
IOWRT ACC
//MOV A,#01h
CALL $WAIT_LCD
RETURN
$WRITE_TEXT
BITSET RS
IOWRT ACC
CALL $WAIT_LCD
RETURN
#include "REG52.H"
// define some needed variant
sbit RS =P1^0;
sbit RW =P1^1;
sbit EN =P1^2;
sbit BUSY =P3^7;
// character dislay
#define CHU_A 0x41
#define CHU_B 0x42
#define CHU_C 0x43
#define CHU_D 0x44
#define CHU_E 0x45
#define CHU_F 0x46
#define CHU_G 0x47
#define CHU_H 0x48
#define CHU_I 0x49
#define CHU_J 0x4A
#define CHU_K 0x4B
#define CHU_L 0x4C
#define CHU_M 0x4D
#define CHU_N 0x4E
#define CHU_O 0x4F
#define CHU_P 0x50
#define CHU_Q 0x51
#define CHU_R 0x52
#define CHU_S 0x53
#define CHU_T 0x54
#define CHU_U 0x55
#define CHU_V 0x56
#define CHU_W 0x57
#define CHU_X 0x58
#define CHU_Y 0x59
#define CHU_Z 0x5A
#define KT 0x20
#define DATA P3
//declare my fundtion
void WAIT_LCD(void);
void INT_LCD(void);
void WR_LCD( unsigned char TXT);
void CLR_LCD (void);
void HOME_LCD (void);
//main program
void main(void)
INT_LCD();
CLR_LCD();
HOME_LCD();
WR_LCD(CHU_B);
WR_LCD(CHU_A);
WR_LCD(CHU_O);
while(1);
void WAIT_LCD(void)
DATA=0xFF;
EN=1 ;
RW=1 ;
RS=0 ;//command
while (BUSY)
EN=0;
RW=0;
void INT_LCD(void)
//function set 8 col 2 row, 5x7 dot format
EN=1;
RS=0;
DATA=0x38;
EN=0;
WAIT_LCD();
// Dislay ON/OFF CURSOR Shift
// dislay ON, Cursor Underline on, cursor blink off
EN=1;
RS=0;
DATA=0x0E;
EN=0;
WAIT_LCD();
//Set Charracter Mode
// increment (dich fai) , Dislay Shift Off
EN=1;
RS=0;
DATA=0x06;
EN=0;
WAIT_LCD();
RS=1 ;
EN=1 ;
DATA=TXT ;
EN=0 ;
WAIT_LCD() ;
void CLR_LCD(void)
EN=1;
RS=0;
DATA=0x01;
EN=0;
WAIT_LCD();
{EN=1;
RS=0;
DATA=0X02;
EN=1;
WAIT_LCD();
vijaya_narayana said:;;;;;;;;;;;;;;;pin assignment;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
db0 equ p1.0
db1 equ p1.1
db2 equ p1.2
db3 equ p1.3
db4 equ p1.4
db5 equ p1.5
db6 equ p1.6
db7 equ p1.7
enable equ p2.2
rs equ p2.0
rw equ p2.1
dat equ p1
;;;;;;;;;;;;;;;;;;LCD COMMAND SEQUENCE;;;;;;;;;;;;;;;;;;;
com: mov dat,a
clr rs
clr rw
setb enable
clr enable
call wait
ret
;;;;;;;;;;;;;;;;;;;LCD WRITE SEQUENCE;;;;;;;;;;;;;;;;;;;;
lcd_write: mov dat,a
setb rs
clr rw
setb enable
clr enable
call wait
ret
;;;;;;;;;;;;;;;;;;;;LCD clear screen SEQUENCE;;;;;;;;;;;;;;;
lcd_clr: mov a,#01h
call com
ret
here is the code for 8051 in assembly language just call the write sequence after u pass the letter
u want to display with a delay
Added after 57 seconds:
if u need more details then i can write a sample code in assembly and post it
#include <REG2051.H>
#define lcd_port P3
//LCD Registers addresses
#define LCD_EN 0x80
#define LCD_RS 0x20
//LCD Commands
#define LCD_CLS 0x01
#define LCD_HOME 0x02
#define LCD_SETMODE 0x04
#define LCD_SETVISIBLE 0x08
#define LCD_SHIFT 0x10
#define LCD_SETFUNCTION 0x28
#define LCD_SETCGADDR 0x40
#define LCD_SETDDADDR 0x80
#define FALSE 0
#define TRUE 1
***** FUNCTION PROTOTYPES *****
void lcd_init();
void lcd_reset();
void lcd_cmd (char);
void lcd_data(unsigned char);
void lcd_str (unsigned char*);
#include "lcd.h"
#include "delay.h"
void lcd_reset()
lcd_port = 0xFF;
delayms(20);
lcd_port = 0x03+LCD_EN;
lcd_port = 0x03;
delayms(10);
lcd_port = 0x03;
delayms(1);
lcd_port = 0x03;
delayms(1);
lcd_port = 0x02+LCD_EN;
lcd_port = 0x02;
delayms(1);
void lcd_init ()
unsigned char i;
lcd_reset();
lcd_cmd(LCD_SETFUNCTION); // 4-bit mode - 1 line - 5x7 font.
lcd_cmd(LCD_SETVISIBLE+0x04); // Display no cursor - no blink.
lcd_cmd(LCD_SETMODE+0x02); // Automatic Increment - No Display shift.
lcd_cmd(LCD_SETCGADDR);
for(i=0;i<8;i++)
lcd_data(lockicon[i]);
for(i=0;i<8;i++)
lcd_data(unlockicon[i]);
for(i=0;i<8;i++)
lcd_data(ex[i]);
for(i=0;i<8;i++)
lcd_data(ok[i]);
lcd_cmd(LCD_SETDDADDR); // Address DDRAM with 0 offset 80h.
void lcd_cmd (char cmd)
lcd_port = ((cmd >> 4) & 0x0F)|LCD_EN;
lcd_port = ((cmd >> 4) & 0x0F);
lcd_port = (cmd & 0x0F)|LCD_EN;
lcd_port = (cmd & 0x0F);
delayus(200);
delayus(200);
void lcd_data (unsigned char dat)
lcd_port = (((dat >> 4) & 0x0F)|LCD_EN|LCD_RS);
lcd_port = (((dat >> 4) & 0x0F)|LCD_RS);
lcd_port = ((dat & 0x0F)|LCD_EN|LCD_RS);
lcd_port = ((dat & 0x0F)|LCD_RS);
delayus(200);
delayus(200);
void lcd_str (unsigned char *str)
while(*str){
lcd_data(*str++);
#include "delay.h"
void delayus(unsigned char delay){
while(delay--);
void delayms(unsigned char delay){
while(delay--)
delayus(149);
#ifndef __DELAY__
#define __DELAY__
void delayus(unsigned char);
void delayms(unsigned char);
#endif
I am professional LCD engineer for some years and I have a lot of LCD Program and LCD datasheet. If any worldwide friends needed, I would like to email you as soon as possible. Pls. email me firstly.
Can you post its circuit?
---------- Post added at 07:25 ---------- Previous post was at 07:20 ----------
Can you post simple LCD circuit on 8051 and c coded?
