Problem with ISP programming of Atmel 89S52
Js_Ong
Member level 4
Hi, I am using the Assim Khan ISP programming to program the ATMEL 89s52 microcontroller, I am trying to develope the hardware and testing it now. when I press 'Read', my machine is reading from the microntroller, but when I was trying to write the file into my chip, there were buffer read error, saying the Read data and prog data are not same. This happened every time when I tried to click the write file, and the arror at the address was not constant, it changed. I tried to check so many times, PLS HELP!!! I need it to program my project since I do not know how to program using Serial Communication...
Re: ISP Programming
Hi Koson, I tried to remove some resistor from the output of the buffer, now is ok.
Re: ISP Programming
check your MOSI line for loose connections. It happens most of the time for loose connections
Re: ISP Programming
did any one make layout for this isp programmer,
if so plz upload it ,
