Problem with IPs in MHS file (EDK 6.1)
LatDrIvE
Member level 4
athens
Hello all:)
I am running a design in edk 6.1 version. and comes up with
" Makefile cannot be saved to run process. Please ensure IPs in MHS file point to the right MPDs".
The MHS doesnt contain info about MPDs..
What i have to do on that?
regards
Re: IPs in MHS file
Hi
This is the problem with tool. Go to XPS n clean all generated files ...rebuild it so MHS file is updated.
Re: IPs in MHS file
i am trying but it says could not open system.make for writing Makefile
Added after 19 minutes:
ok done it:) this was the only file that its properties was set as "read only" . so dump... thanx :)
