#include <p18f47j53.h>
#include <delays.h>
#include <portb.h>
#pragma config OSC = HS
#pragma config WDTEN = OFF
#pragma config XINST = OFF
int x,y;
void InterruptServiceHigh(void);
void InterruptServiceLow(void);
void main(void)
INTCONbits.INT0IF = 0;
INTCONbits.INT0IE = 1;
INTCON2bits.INTEDG0 = 1;
RPINR2 = 5;
INTCON3bits.INT2IF = 0;
INTCON3bits.INT2IE = 1;
INTCON3bits.INT2IP = 1;
INTCON2bits.INTEDG2 = 1;
INTCON2bits.RBPU = 0;
EnablePullups();
TRISE = 0;
TRISBbits.TRISB0 = 1;
TRISBbits.TRISB2 = 1;
ANCON1bits.PCFG8 = 1;
ANCON1bits.PCFG12 = 1;
RCONbits.IPEN = 1;
INTCONbits.GIE = 1;
INTCONbits.PEIE = 1;
while(1)
PORTE = 0x03;
// Interrupt Service Routine
// High priority interrupt vector
#pragma code InterruptVectorHigh = 0x08
void InterruptVectorHigh(void)
_asm
goto InterruptServiceHigh
_endasm
// Low priority interrupt vector
#pragma code InterruptVectorLow = 0x18
void InterruptVectorLow(void)
_asm
goto InterruptServiceLow
_endasm
// Interrupt pragma for high priority
#pragma code
#pragma interrupt InterruptServiceHigh
if(INTCONbits.INT0IF)
x = 0;
while(x <= 2)
PORTE = 0x01;
Delay10KTCYx(120); // Delay of 1 sec with 12 MHz
PORTE = 0x02;
Delay10KTCYx(120);
x++;
PORTE = 0x00;
if(INTCON3bits.INT2IF)
x = 0;
while(x <= 2)
PORTE = 0x00;
PORTE = 0x03;
Delay10KTCYx(120);
x++;
PORTE = 0x00;
} // return from high priority interrupt
// Interrupt pragma for low priority
#pragma code
#pragma interrupt InterruptServiceLow
// function statements
// return from low priority interrupt
