Problem with interfacing PIC with SID13305 in 320X240 GLCD display
swapgo
Full Member level 2
Full Member level 2
India
Hi All
I am interfacing PIC with SID13305 in 320X240 GLCD display.
I use ccsc compiler with PIC18f6722. I am using the driver file sed1335.c.
I am able to initilize and write to the LCD.
But the reading the display memory is not proper.
I think I need to use a pull down for datalines!!
Is my assumption is correct? Or any other Suggestions?
Thanks and Regards
Gopi
sed1335.c pic
Did you have it to work
I have also a problem to get it work
sid13305 driver
It working now, has made some changes
PIC with SID13305
Is the sed1335.c provide by the chip vendor?
Re: PIC with SID13305
No, it is by CCS-C compiler
