youngwx
Newbie level 3
When I install install Cadence IC614 on CentOS 6.0 I meet with the following problems, that is the InstallScape window doesn't jump out when I type in the route
Anyone who knows how to solve this problem? Thanks very much! :-D
This is what displayed on the terminal:
Extracting InstallScape version 03.71.s01
for platform lnx86 in /home/ASIC/cadence/installscape
Starting up InstallScape in GUI mode
DISPLAY environment variable is set to :0.0
If you do not see the InstallScape console
window or the it seems to be hanging then kill this
process.
Set your DISPLAY environment variable to a proper
value and manually start InstallScape by typing:
/home/ASIC/cadence/installscape/iscape/bin/iscape.sh /home/ASIC/cadence_install/ic614/IC06.14.501-614_lnx86.Hotfix/CDROM1:::/home/ASIC/cadence/ic614
Initializing InstallScape using JVM at /home/ASIC/cadence/installscape/iscape/runtime/LNX86/bin/java. This might take some time...
Exception in thread "main" java.lang.UnsatisfiedLinkError: /home/ASIC/cadence/installscape/iscape/runtime/LNX86/lib/i386/xawt/libmawt.so: Can't load IA 32-bit .so on a IA 32-bit platform
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1751)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1647)
at java.lang.Runtime.load0(Runtime.java:769)
at java.lang.System.load(System.java:968)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1668)
at java.lang.Runtime.loadLibrary0(Runtime.java:822)
at java.lang.System.loadLibrary(System.java:993)
at sun.security.action.LoadLibraryAction.run(LoadLibraryAction.java:50)
at java.security.AccessController.doPrivileged(Native Method)
at java.awt.Toolkit.loadLibraries(Toolkit.java:1509)
at java.awt.Toolkit.<clinit>(Toolkit.java:1530)
at com.khanpur.installer.gui.InstallerUI.main(InstallerUI.java:85)
process.
