Problem with installing sysgen in matlab 7.
siosavin
Member level 4
I want to install sysgen 6.1.1 in matlab 7. But when i install sysgen, flllowing warnings occured:
Welcome to the Xilinx System Generator Version 6.1.1 Installer.
Warning: PATH2RC is deprecated and may be removed in a future release. Use SAVEPATH instead.
> In path2rc at 11
In xlSysgenInst at 220
In xlInstallAction at 186
> In path2rc at 11
In xlSysgenInst at 341
> In path2rc at 11
In xlSysgenInst at 527
> In path2rc at 11
In xlSysgenInst at 551
Your MATLAB classpath.txt has been updated; before using the Xilinx BlockSet,
please restart MATLAB.
Warning: Function call xlNormalizepath invokes inexact match C:\MATLAB7\toolbox\xilinx\sysgen\bin\xlNormalizePath.p.
> In xlprocessdoc at 6
In xlInstExtra at 45
In xlSysgenInst at 592
Also when i browse xilinx blockset, following error occured:
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : EXCEPTION_ACCESS_VIOLATION occurred at PC=0x7813CEF9
Function=[Unknown.]
Library=C:\MATLAB7\sys\java\jre\win32\jre1.4.2\bin\client\jvm.dll
NOTE: We are unable to locate the function name symbol for the error
just occurred. Please refer to release documentation for possible
reason and solutions.
Current Java thread:
at java.lang.Thread.currentThread(Native Method)
at java.lang.Thread.init(Unknown Source)
at java.lang.Thread.<init>(Unknown Source)
Local Time = Sun Jun 27 11:25:56 2004
Elapsed Time = 2
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (1.4.0-b92 interpreted mode)
These is not occured when i install this sysgen in matlab 6.5.
Does anyone can help me to solve this problem?
HI!
you had that error cos the SG6.1.1 is not supported by matlab 7 you need SG6.2
from the EEtimes news
the new version 6.2 release of the Xilinx System Generator for DSP development tool that fully supports the MATLAB 7 and Simulink 6 software packages also introduced as part of The MathWorks Release 14.
good luck, bart
Xilinx has released two versions of SG6.2, one for MATLAB-R13 and the other for MATLAB-R14. Evaluation versions can be downloaded from the following page after registering.
hi friends
I have matlab release 13 version6.5. where can I download the free version or evaluation of XILINX toolbox for the matlab?
thank you.
hello
but I want more specified address because I cant find it
thanks
