patriot
Member level 5
impedance matching?
i am confused with the impedance matching,when using the ADS tool"impedance matching utility",the source impedance is the conjugate of Zin2,the load impedance is 50 ohms.After adding the tool-designed matching network to the circuit,the output impedance gets smaller,nearly zero,that is to say farther from 50 ohms.what is the matter?
can anyone suggest me a detailed topology of the matching network?very urgent
thanks very much!
following is the output impedance(without including the stopping-capacitor)
freq1 Zin2
1.30000000000000000E9 9.78340452845667490E-1 + j2.32473486456278170E0
1.31000000000000010E9 9.74940022168845570E-1 + j2.37291833496453420E0
1.31999999999999980E9 9.73043456307617300E-1 + j2.41992627184477050E0
1.33000000000000010E9 9.72692984677364510E-1 + j2.46547423862163930E0
1.34000000000000010E9 9.74128282023430000E-1 + j2.50930789001569200E0
1.35000000000000010E9 9.77648682736302990E-1 + j2.55093036195757470E0
1.35999999999999990E9 9.82855984718990070E-1 + j2.58928644985481290E0
1.36999999999999990E9 9.89078047575209500E-1 + j2.62364618064408810E0
1.38000000000000010E9 9.96948108401825190E-1 + j2.65310998260406720E0
1.39000000000000010E9 1.00540755629910870E0 + j2.67613679621787040E0
1.39999999999999990E9 1.01391701086935940E0 + j2.69081581744140140E0
1.40999999999999990E9 1.02037190078315600E0 + j2.69471908461638820E0
1.41999999999999990E9 1.02129939990832220E0 + j2.68498382449949610E0
1.43000000000000020E9 1.01097421455956950E0 + j2.65871366298249350E0
1.43999999999999990E9 9.79219451170753000E-1 + j2.61485613429572570E0
1.45000000000000000E9 9.11792798460039580E-1 + j2.55767216934097470E0
1.46000000000000000E9 7.92189036726127420E-1 + j2.50402187774351280E0
1.47000000000000000E9 6.15046162773490050E-1 + j2.48919054451372230E0
1.48000000000000000E9 4.06291301467546530E-1 + j2.55247974795779340E0
1.49000000000000000E9 2.21316364027033070E-1 + j2.70334942704004840E0
1.50000000000000000E9 1.03615955777927680E-1 + j2.90786087843425540E0
1.51000000000000000E9 5.65935583268237790E-2 + j3.11846591422005390E0
1.52000000000000000E9 5.85085623636769190E-2 + j3.30737506543891560E0
1.53000000000000000E9 8.63127302105252700E-2 + j3.46743280305691790E0
1.54000000000000000E9 1.25161137748894790E-1 + j3.60187389562484390E0
1.55000000000000000E9 1.66950921196448430E-1 + j3.71647831007003670E0
1.56000000000000010E9 2.08016615270152090E-1 + j3.81638593867748370E0
1.56999999999999980E9 2.46663636592279540E-1 + j3.90556331948583060E0
1.58000000000000010E9 2.82484483895792550E-1 + j3.98695065489327630E0
1.59000000000000010E9 3.15542642878627210E-1 + j4.06256464949570000E0
1.60000000000000010E9 3.46077236149308790E-1 + j4.13392012528315880E0
1.61000000000000010E9 3.74468681632549270E-1 + j4.20206571156040100E0
1.61999999999999990E9 4.01022538037032210E-1 + j4.26772178051947470E0
1.63000000000000010E9 4.26037868475390270E-1 + j4.33147921745088650E0
1.63999999999999990E9 4.49800998197654600E-1 + j4.39371037614776490E0
1.64999999999999990E9 4.72589363550043200E-1 + j4.45472856519722440E0
1.66000000000000010E9 4.94530274897668050E-1 + j4.51473734613535440E0
1.66999999999999990E9 5.15858526557989360E-1 + j4.57391073192073350E0
1.68000000000000020E9 5.36729241683042880E-1 + j4.63238998577480300E0
1.68999999999999990E9 5.57258163919306960E-1 + j4.69028973968307650E0
1.70000000000000000E9 5.77571620858129010E-1 + j4.74771518833811520E0
1.71000000000000020E9 5.97834804647683790E-1 + j4.80472969071529740E0
1.72000000000000000E9 6.18100864909803870E-1 + j4.86145935715103850E0
1.73000000000000000E9 6.38530568327827640E-1 + j4.91800046192519340E0
1.73999999999999980E9 6.59329678604730420E-1 + j4.97453649714462550E0
1.75000000000000000E9 6.80738433750017790E-1 + j5.03124018248771330E0
1.76000000000000020E9 7.03114716308466200E-1 + j5.08836212257973660E0
1.77000000000000000E9 7.27129728217877160E-1 + j5.14622203552351910E0
1.78000000000000000E9 7.53679894058555620E-1 + j5.20506144193573930E0
1.78999999999999980E9 7.84260150449684530E-1 + j5.26520026760072920E0
1.80000000000000000E9 8.21272365354386840E-1 + j5.32677692644841820E0
1.81000000000000010E9 8.68525247310467560E-1 + j5.38955288583425230E0
1.81999999999999980E9 9.32593716217874300E-1 + j5.45260172847116480E0
1.83000000000000010E9 1.02696171868592900E0 + j5.51258886881019980E0
1.83999999999999990E9 1.18352753523598930E0 + j5.55746352617253690E0
1.85000000000000010E9 1.49117534273850020E0 + j5.51587994730228900E0
1.86000000000000010E9 2.03254722595791690E0 + j4.78613066948074020E0
1.86999999999999990E9 1.98424698560360580E-1 + j4.08201572761991120E0
1.88000000000000010E9 9.06937266534016120E-2 + j5.16891765062816330E0
1.88999999999999990E9 2.86192427303025720E-1 + j5.50955054405823130E0
1.89999999999999990E9 4.12235889292521480E-1 + j5.67563868689117700E0
thanks very much!
freq1 Zin2
