Hi All,
In the board I designed , I am using Power jack connector (similar to the one we have on laptop). Input to the board is 12 V. I have voltage regulators to generate other voltages like 3.3, 2.5 etc on board from 12 V input.
The problem is when I connect the voltage adapter to the board , it is not generating the correct voltages however if I also connect it to an external ground everything works fine. So I think The board is not getting ground
attached is the snapshot of the power jack connector connection,
Any help will be really appreciated.
Thanks
