Register Log in
[SOLVED] Problem with GLCD , Images are displaying but no text.
Magnatron
Full Member level 2
Deolali
Hi, I stumble upon a compiler called "mikro C pro for pic". Created a code for displaying some pictures, but texts are all messed up!:-? on protues simulation, it seemed to be working allright, but on the real stuff the text get all messed up!:sad: did anyone encounter the same problem?? I'm using a Graphic LCD module part name JHD 12864E controller:(KS0108), and PIC16f877a MCU @ 8 mhz
const code char LOGO[1024] = {
   ///**some numbers ** //
//--------------------------------------------------------------end-declarations
// Glcd module connections
char GLCD_DataPort at PORTB;
sbit GLCD_CS1 at RC2_bit;
sbit GLCD_CS2 at RC3_bit;
sbit GLCD_RS  at RC0_bit;
sbit GLCD_RW  at RC5_bit;
sbit GLCD_EN  at RC1_bit;
sbit GLCD_RST at RC4_bit;
sbit GLCD_CS1_Direction at TRISC2_bit;
sbit GLCD_CS2_Direction at TRISC3_bit;
sbit GLCD_RS_Direction  at TRISC0_bit;
sbit GLCD_RW_Direction  at TRISC5_bit;
sbit GLCD_EN_Direction  at TRISC1_bit;
sbit GLCD_RST_Direction at TRISC4_bit;
// End Glcd module connections
void delay2S(){                             // 2 seconds delay function
  Delay_ms(2000);
void main() {
  unsigned short ii;
  char *someText;
  Glcd_Init();                              // Initialize GLCD
  Glcd_Fill(0x00);                          // Clear GLCD
  while(1)
      Glcd_Image(LOGO);                // Draw image
      Glcd_Set_Font(font5x7, 5, 7, 32);     // Change font
      Glcd_Write_Text("V 1.0", 99, 0, 2); //[COLOR="#FF0000"] :!:not work right[/COLOR]
      Glcd_Write_Text("Date", 0, 0, 2); //[COLOR="#FF0000"] :!:not work right[/COLOR]
       delay2S();
Protues simulation:
GLCD test :
can any one help:?:
Magnatron
Full Member level 2
Deolali
  Delay_ms(2000);
void main() {
  unsigned short ii;
  char *someText;
  while(1)
       delay2S();
Protues simulation:
GLCD test :
can any one help:?:
Glcd_Write_Text("V 1.0", 99, 0, 2); // :!:not work right
Glcd_Write_Text("V 1.0", 99, 0, 1); // :!: work right
Toggle Sidebar
