GeoAVR
Member level 2
- Joined
- Jun 4, 2014
- Messages
- 48
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 6
- Activity points
- 366
Hi all,
I have a sensor with a Bandwidth of 10Hz to 50kHz.
I have observed that sometimes I get noise spikes at 20Hz and 60Hz. I believe it is because of the long wire of the sensor and the noisy (industrial) environment.
At first I though of using a high pass or notch filter to remove the spikes but the problem is that at the noise frequencies are also signal frequencies.
What can I do?
Thank you in advance.
What can I do?
