Problem with external interrupts
Swys
Junior Member level 1
I really hope someone can help me on this. I have to count pulses from an external source. For some reason, only the first pulse is counted. Can someone please have a look at my code to see what I am doing wrong?
I am using the MPLAB C18 compiler with a PIC18F13K50
Here are my interrupt functions:
#pragma code high_vector=0x08
void interrupt_at_high_vector(void)
	_asm
		GOTO high_isr
	_endasm
#pragma code
#pragma interrupt high_isr
void high_isr(void)
	if ((INTCONbits.INT0IF == 1) &  (INTCONbits.INT0IE == 1))
		//Pulse received
		INTCONbits.INT0IF = 0;
		flow_int = 1;        //Flag indicating when interrupt occurred
		//PORTCbits.RC0 = 1;
This is how my PIC is set up:
void SetupPIC(void)
	//Setup ports
	TRISA = 0x00;
	TRISB = 0x00;
	TRISC = 0x00;
	PORTA = 0;
	PORTB = 0;
	PORTC = 0;
	//Disable all analog inputs
	ANSEL = 0x00;
	ANSELH = 0x00;
	//Setup USART
	TRISBbits.TRISB5 = 1;
	TRISBbits.TRISB7 = 1;
	//SetupUART();
	OpenUSART(	USART_TX_INT_OFF	&
				USART_RX_INT_ON		&
				USART_ASYNCH_MODE	&
				USART_EIGHT_BIT		&
				USART_CONT_RX		&
				USART_BRGH_HIGH,
				129);
	PIE1bits.RCIE = 1;		//Enable USART receive interrupt
	PIR1bits.RCIF = 0;		//Clear USART receive interrupt flag
	//Setup FRAM
	init_FRAM();
	//Setup ADC
	init_ADC();
	TRISCbits.TRISC6 = 0;
	//Setup Timers
	//Timer0
	T0CON = 0b00000111;		//Timer stopped;16-bit timer;
							//Internal instruction cycle clock;
							//Timer0 prescaler assigned;
							//1:256 prescale value
	INTCONbits.TMR0IE = 1;	//Enable Timer0 interrupts
	INTCONbits.TMR0IF = 0;	//Clear Timer- interrupt flag
	//Setup external interrupts INT0 and INT1
	INTCONbits.INT0IF = 0;	//Clear the interrupt flag
	INTCONbits.INT0IE = 1;	//Enable external interrupt INT0
	INTCON2bits.INTEDG0 = 0;//Interrupt on the falling edge
	PORTCbits.RC0 = 1;		//Pull HIGH to create falling edge
							//on contact
	INTCON3bits.INT1IE = 1;	//Enable external interrupt INT1
	INTCON2bits.INTEDG1 = 0;//Interrupt on the falling edge
	INTCON3bits.INT1IF = 0;	//Clear the interrupt flag
	PORTCbits.RC1 = 1;
	INTCONbits.PEIE = 1;
	INTCONbits.GIE = 1;
In my main function, I am just checking the flow_int flag and outputting some text on the UART when the flag is set. Please help, since I don't have much time to solve this?
P.S. I've tried it with PORTCbits.RC0 = 1 and PORTCbits.RC0 = 0
Maybe a silly question, but are you clearing the 'flow_int' flag after checking it in your main routine?
Not silly, I've overlooked something like that quite a few times, but yes, I am clearing that flag
I cant see where you have set up INT0, RC0 as an input?
    Swys
Thanks, that was the problem. I didn't realize it should be an input. I changed it...and it works!
Thanks guys!
