Problem with dspic33 as there is no voltage at output pins
gsg
Junior Member level 1
I'm trying to send all 1's to output pins of dspic33fj128mc202. My programming and verification is done correctly. But there is no voltage at output pins. Here's the code
#include <p33FJ128MC202.h>
 int main(void)
    AD1PCFGL = 0xffff; //All analog capable pins in digital mode
    TRISA = 0; //All pins output
    TRISB = 0; //All pins output
    PORTA = 0xFFFF; //All pins low
    PORTB = 0xFFFF; //All pins low
    while(1);
    return 0;
The output at all pins is :
Pin28: 3.3v
pin13: 3.3v
Pin1: 3.3v
Pin20: 2.6v
All other pins: 0v
can the IC be damaged?
What are the indications that a dspic is damaged?
Re: dspic33 no output
What are the settings for the configuration bits. The main problem can be with the oscillator. what hardware are you using to program the chip? If it is recognized by tne programmer then the the chip is probably ok.
Regards.
These are the configuration bit setting i tried using:
_FOSCSEL(FNOSC_FRC);
_FOSC(FCKSM_CSECME & OSCIOFNC_ON & POSCMD_NONE);
Is there anything else i need to do with the configuration bits ?
I'm using a Pickit2 for programming.
dspic33 no output
Try these settings:
_FOSCSEL(FNOSC_FRCPLL);
_FOSC(FCKSM_CSECMD & OSCIOFNC_ON  & POSCMD_NONE);
And put the settings in the code, using the MPLAB configuration thing didn't work for me when I tried, so I put the config settings in the code.
Try this:
 int main(void)
    while(1);
Hope this helps.
Tahmid.
Thanks
I tried changing the config bit setting but there's no change. there's simply no output.
Please help..
THANX...Tahmid....this post solved my problem...hats off for u.........
