Problem with displaying digits on a LCD
eason_terrorist
Hey everyone,
I have some problem with my LCD.
The problem is when i from 1 increase to 100, the LCD show normal.
But i decrease from 100 to 1, there is some problem showing in the LCD
when from 100 decrease to 99, my lcd will show 990----> how to clear the zero behind the 99?
DineshSL
Advanced Member level 1
Sri Lanka
Re: Problem with the LCD
Best way is to write all 3-digits every time. Then number is aligned to right; So it would be 001,002,...099,100.
For that you may write Hundreds-digit first then tens-digit then units-digit.
When you decrease also, you should write all three digits; so it would be 100,099,098...001
Or you may write "Space" (ASCII 32) when ever you want to delete a character where cursor is at; this way you can remove un-necessary tailing digits.
Wish you success !
eason_terrorist
thank for reply....can u show me some example?i dun understand how to do that
VSMVDD
Banned
scotland uk
if its c your using
when you printf the value
you can use
%.1d this gives 2 decimal number or
like
char decimal=23;
printf( "%.1d",decimal);
will print 23 and not 23.0 or 023
Tips on printf
see here for a list of the control charicters for printf
DineshSL
Sri Lanka
Follow this tutorial;(it's in Mplab-assembly)
PIC Tutorial  Three - LCD Modules -Tutorial 3.2
It converts 16bit Binary to Decimal and store 5 digits on separate 5 registers;
Then it always writes these 5 digits on LCD.
I guess you count something like a pulse; which always have increment or decrement by 1 only. Is it ?
If so it would be more easy to code. If you explain how you have stored your number in memory(like in a single-register or 3-registers for 3-digits); more specific explanation can be showed.
Thank you,
