nine degrees of freedom ahrs
Hi
You didn’t reveal application for which you are using AHRS500. What kind of problem you are facing? Also you have not mentioned type of AHRS500, whether its AHRS500C (Commercial Aviation), AHRS500G (General Aviation) or AHRS500M (Marine)?
Wulfsberg Electronics provided us EFIS and the sensor came in package. We had some problem with the product, we complaint to Wulfsberg then they resolved this issue by replacing AHRS500CA with AHRS500GA-222.
Initially Crossbow developed AHRS400 for industrial and aerospace market but FAA refused to approve this for use in aircrafts .Crossbow recognized need for certification and developed AHRS500CA for avionics application to meet FAA certification requirements but it has some malfunctions (caging, limited rate and speed problems) and also it doesn’t comply with DO-160D then Crossbow designed AHRS500GA for improved cold start reliability and acceleration and deceleration performance improvements.
If you are not using it in Aircraft then it would be better to use IMU400, VG400 or AHRS400.
Cheers
