Problem with cylindrical 8 patch antenna array, CST
chrisskos
Hi all,
I am designing an antenna array, on CST Microwave Studio, consisted from 8 rectangular patches printed on a surface an a cylinder with coaxial feed. When i am trying to simulate the geometry i have an error :
Waveguide ports must be aligned with Cartesian coordinate planes for the
transient solver.
I know that the ports must be parallel on one axis x,y or z. Does anyone know how can i resolve these problem considering that i would like to simulate the farfields
Thanks in advance
p.s the array geometry is presented below
abdoeng
Advanced Member level 2
try to use disceret port instead waveguide
chrisskos
Thank you for your response, i tried to use discrete ports but it didn't work either because of the formulation of the geometry, i resolved this problem in an alternative way. I expanded and rotate the coaxial feed by 45 degrees in order to to have the port planes in one axis each time. It is a bit difficult geometry but i hope to get some results. Thank you again for your help.
abdoeng
hi chrisskos
,could upload ur file so it may be useful for us
regards
chrisskos
Hi abdoeng,
I haven't quite finished the simulation of the array, so it is not completed yet. I will uploaded when i can have complete results because when i try to simulate i get the message that the memory is not enough, as so i have to think of something else. When i upload the project i could sent you a pm if you want. Please let me know.
Thank you in advance for your patience
abdoeng
just try upload ur file,may i could look it
regards
cplia
Member level 2
Member level 2
Europe
Was wondering how you added the curved metalized plates on the ring. Did you
create any special macro for this purpose, or used any existing ones?
Nice geometry, I like it!
primoanimation
Newbie level 2
Newbie level 2
Where can i download the file? i have a similar problem with a conformal antenna array,
I have done an adecuation to the coaxial probe, but i doesnt works good.
Thanks!
