Hi
I am using cypress cy7c68013a-100a and driver cyusb.sys in "Cypress Suite USB 3.4.6"
for win 7 in wlh folder.
and change .inf file (my .inf is attached)
and build a board according AN15456 in this address
When I connect on some PC's running Windows 7, i see "the device is not recognized" and "this device connot start(code10)"!
* i can't find 'tps3820-33' for reset pin so i use a 100k from reset pin to 3.3v and a 0.1uf to gnd *
Your problem could be the 100KΩ resistor you are using as a pullup on the RESET pin. Try dropping it down to 10KΩ and swap out the 0.1µF cap for a 1µF cap.
The device maybe stuck in reset state.
Below is a schematic for a custom development board which may give you some pointers. I would also advise you to post your schematic, there maybe other issues as well.
Hi
thank bigDog for your answer and sorry because of delay my reply
this is my schematic .please look at and tell me your suggestion View attachment usb.pdf
i change res & cap for reset pin but not any thing happen
so i look at "The Uncomplicated Universal Usb board " as soon as possible
