Problem with converting IR sensor's output to digital form
muiz
Newbie level 1
I'm having problem with my IR sensor. It gives output in analog form but to use it with my microcontroller, i need dome device to convert it to digital form. for that i had used potentiometer. But it isn't working properly. Can you suggest some handy device for this purpose? :!:
D.A.(Tony)Stewart
Advanced Member level 5
Richmond Hill, ON, Canada
Re: Problem with Sensors
most uC's have analog to digital convertors. What signal range and frequency response DC to ? or AC to? what is it for?
milind.a.kulkarni
Advanced Member level 3
Bangalore
One aspect is about A to D conversion....the second one is getting signal conditioning properly.....you need to design the proper signal conditioning circuit with noise filtered ( A good R C filter ) , High input impedance, range and gain adjustable circuit.....May be using Opamp ......to get the reading properly
Good Luck
Jigar 4 Electronics
Full Member level 5
Hamilton, ON, Canada
Sensor ---> Op-Amp ---> ADC ---> uC
This will be the better way for you.
or post the actual aim which want to do.
